Has onymone managed to integrate this into HA?
Seems to work on ioBroker
yes I was able to do this. I have used this ESPHome config as a baseline:
Heidelberg Wallbox · martgras/esphome Wiki (github.com)
I reduced the sensors to a minimum:
uart:
tx_pin: GPIO03
rx_pin: GPIO01
baud_rate: 19200
stop_bits: 1
parity: even
modbus:
send_wait_time: 200ms
uart_id: mod_bus
modbus_controller:
- id: heidelberg_wallbox_id01
address: 0x1
modbus_id: modbus_heidelberg_wallbox
command_throttle: 200ms
setup_priority: -10
update_interval: 5s
- platform: modbus_controller
modbus_controller_id: heidelberg_wallbox_id01
address: 0x0005
register_type: read
value_type: U_WORD
skip_updates: 0
address: 0x0101
unit_of_measurement: "ms"
register_type: holding
value_type: U_WORD
skip_updates: 0
address: 0x0105
unit_of_measurement: "A"
value_type: U_WORD
skip_updates: 0
accuracy_decimals: 0
filters:
- multiply: 0.1
- platform: homeassistant
entity_id: input_number.wb_max_current #Slider from HASS, create as Helper
internal: true
on_value:
then:
- lambda: |-
uint16_t payload = id(wb_max_current).state * 10;
ESP_LOGI("main", "set max current %d", payload);
// Create a modbus command item with the max current value as the payload
esphome::modbus_controller::ModbusCommandItem set_payload_command = esphome::modbus_controller::ModbusCommandItem::create_write_single_command(heidelberg_wallbox_id01, 0x0105, payload);
// Submit the command to the send queue
heidelberg_wallbox_id01->queue_command(set_payload_command);
The Charging State signals if a car is connected and if charging is required. For the automation and managing the load I use Node-Red.
When the state switches to 4 or 5 (car is connected, no charging request) the charging state will be set to 6 (6A). This is the minumim charging allowed by Heidelberg.
This will allow charging and when the car requires charging the state will switch to 7.
The next flow will check every 5 seconds for the charging state (7) and than will check on what will still be transfered to the grid.
My Mercedes allows 2 phase charging - so 1A x 230V * 2 phases is 460kW. When more than 460kW will go to the grid, the Max Current will be increased by one (and if not, it will be decreased).
I just finshed yesterday and still testing. But first test was successful.
Br,
walzing
Hi Walzing,
thank you for your time and effort. I recently integrated our PV system into HA, now the next step is to integrate our Heidelberg Energy Control via Modbus into HA, and make the two “talk to each other”.
I have to admit that I have limited knowledge on programming and IT in general. Do you know of a source that describes your implementation in a more detailed way? A step-by-step procedure would be amazing of course, but anything with more detail would help a lot.
Any additional info is greatly appreciated, thank you!
Aleks
Hello, how is the status?
I have also an Heidelberg Wallbox.
Can I help somehow?
Sorry for my late reply. I haven’t seen your requests.
I can help. I assume both of you have a working esphome and a RS485 modul connected to your Heidelberg?
I tried to connect my heidelberg energy control wallbox to esphome. On the oscilloscope I see the wallbox does answer to a read request, but I allways get crc error
Modbus CRC Check failed! C022!=0E
I used the following setup:
uart:
tx_pin: GPIO23
rx_pin: GPIO22
baud_rate: 19200
stop_bits: 1
parity: even
modbus:
flow_control_pin : GPIO32
uart_id: mod_bus
modbus_controller:
address: 0x1
setup_priority: -10
update_interval: 5s
address: 0x0005
register_type: read
value_type: U_WORD
skip_updates: 0
i tried to get the communication to the heidelberg energy control wallbox working.
I used the used above, but added the flow control pin.
On the oscilloscope i see some communication, but in ESPHome i get crc errors.
captive_portal:
Treiber: MAX485 ESA
DE : 3V3
DI : GPIO23
\RE : GND
RO : GPIO22
uart:
tx_pin: GPIO23
rx_pin: GPIO22
baud_rate: 19200
stop_bits: 1
parity: even
modbus:
uart_id: mod_bus
modbus_controller:
address: 0x1
setup_priority: -10
update_interval: 5s
address: 0x0005
register_type: read
value_type: U_WORD
skip_updates: 0 -
name: “Wallbox Heidelberg_Leistung”
address: 14
register_type: read
value_type: U_WORD
skip_updates: 0 -
name: “Wallbox Heidelberg Spannung L1”
address: 10
register_type: read
value_type: U_WORD
skip_updates: 0 -
name: “Wallbox Heidelberg Spannung L2”
address: 11
register_type: read
value_type: U_WORD
skip_updates: 0 -
name: “Wallbox Heidelberg Spannung L3”
address: 12
register_type: read
value_type: U_WORD
skip_updates: 0 -
address: 0x0101 #257
unit_of_measurement: “ms”
value_type: U_WORD
skip_updates: 0 -
address: 0x0105 #261
unit_of_measurement: “A”
value_type: U_WORD
skip_updates: 0
filters:- multiply: 0.1
internal: true
on_value:
then:
- lambda: |-
ESP_LOGI(“main”, “set max current %d”, payload);
Hi, how did you set the DIP Switches?
Have you added the 120ohm resistor?
What cable have you used and how long is it?
