Heimdall Application Dashboard - working :-)
:house: Heimdall Application Dashboard – Home Assistant Add-on
Hi everyone!
After creating a DokuWiki add-on for Home Assistant, I decided to build another one: Heimdall – a beautiful Application Dashboard that lets you organize and quickly access all your web services and applications in one place.
What is Heimdall?
Heimdall is an elegant, open-source application dashboard with support for hundreds of apps including enhanced links that show live data (like download speeds, temperatures, and more) directly on the dashboard tile.
Features
  • :white_check_mark: Clean and modern dashboard UI
  • :white_check_mark: Supports 100+ apps with Enhanced Links (live stats)
  • :white_check_mark: Persistent data storage in /share/heimdall (survives reinstalls!)
  • :white_check_mark: Supports amd64 and aarch64
  • :white_check_mark: Accessible via port 8888
  • :white_check_mark: Animated GIF backgrounds supported via Custom CSS
  • :white_check_mark: Easy one-click installation
Installation
Add the repository to Home Assistant with one click:
:backhand_index_pointing_right: Link to Add repository – My Home Assistant
Or manually add this repository URL in your Add-on Store:
https://github.com/gregorwolf1973/Hassio_Heimdall
After starting the add-on, open http://homeassistant.local:8888 and you’re ready to go!
Animated Backgrounds :clapper_board:
A fun feature: you can use animated GIF backgrounds by placing your GIF in /config/www/ and adding a single line of Custom CSS in Heimdall settings. Full instructions are in the README on GitHub.
GitHub
Feedback, bug reports and contributions are very welcome! :blush:
