HeimVision Cameras
Has anyone used HeimVision cameras with Home Assistant? If so, would you please share what integration did you use? Thanks,
Hopefully not too late, but I have some basic stuff I discovered. I’m still looking for more, but a solid start. Note: I have six cameras attached to the one NVR. Here’s my configuration.yaml setup:
camera:
  - platform: generic
    still_image_url: http://[[NVR IP]]/cgi-bin/snapshot.cgi?chn=0&u=[[LOGIN]]&p=[[PASSWORD]]
  - platform: generic
    still_image_url: http://[[NVR IP]]/cgi-bin/snapshot.cgi?chn=1&u=[[LOGIN]]&p=[[PASSWORD]]
  - platform: generic
    still_image_url: http://[[NVR IP]]/cgi-bin/snapshot.cgi?chn=2&u=[[LOGIN]]&p=[[PASSWORD]]
  - platform: generic
    still_image_url: http://[[NVR IP]]/cgi-bin/snapshot.cgi?chn=3&u=[[LOGIN]]&p=[[PASSWORD]]
  - platform: generic
    still_image_url: http://[[NVR IP]]/cgi-bin/snapshot.cgi?chn=4&u=[[LOGIN]]&p=[[PASSWORD]]
  - platform: generic
    still_image_url: http://[[NVR IP]]/cgi-bin/snapshot.cgi?chn=5&u=[[LOGIN]]&p=[[PASSWORD]]
Note: For some strange reason, in the above, channel 1 is listed as channel 0, 2 is 1, and so fourth. Just one more strangeness when it comes to HeimVision. I don’t get it; I just accept it.
It you one of the cams in your dashboard, it will refresh every ten seconds or so. However, if you touch/click into that card, it will refresh every two seconds or so. Not perfect, but a solid start.
Here’s some more information on Generic Camera:
I’m exploring additional options and have been dabbling a bit; it seems as though info is very limited. I’ll followup if I have any luck.
Het Brandon, Thanks so much for posting this information it was very helpful. But I think you can do better with the Frigate addon/integration.
Hello, I have not gotten this to work. Where do you get the streamlink for your nvr? Thanks.
Each camera, at least on my system has its own link:
http://192.168.1.43/cgi-bin/snapshot.cgi?chn=0&u=admin&p=
           ā””static ip of NVR       channel# ā”˜ ā””userid & password
Channel number in the URL is weird: ā€œ0ā€ is for channel 1, ā€œ1ā€ is for channel 2, and so forth. I still have the default ā€œadminā€ userid and no password (hence nothing after p= ). You can test this by putting that URL into a browser, and you should get a still image. Reloading will update. Since HA now has the Generic Camera integration, I’ve scrapped it being in configuration.yaml and added it in the UI.
Hopefully this helps. I’ll clarify if anything further is needed
