Hello to all.
Can some one halp mento get HAGreen tobrun again.
I‘m new in this world and didn‘t even real start.
First setup was fine and also acess by tve mobile phone.
After some days HA is offline and i have this Message:>>>
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1079, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 157, in async_install
await entity.async_install_with_progress(version, backup)
File “/usr/src/homeassistant/homeassistant/components/update/init.py”, line 489, in async_install_with_progress
await self.async_install(version, backup)
File “/usr/src/homeassistant/homeassistant/components/home assistant OS/update.py”, line 299, in async_install
await update_core(self.hass, version, backup)
File “/usr/src/homeassistant/homeassistant/components/home assistant OS/update_helper.py”, line 52, in update_core
await backup_core_before_update(hass)
File “/usr/src/homeassistant/homeassistant/components/home assistant OS/backup.py”, line 754, in backup_core_before_update
backup_manager = async_get_backup_manager(hass)
File “/usr/src/homeassistant/homeassistant/components/backup/init.py”, line 134, in async_get_manager
raise HomeAssistantError(“Backup integration is not available”)
homeassistant.exceptions.HomeAssistantError: Backup integration is not availablee[0me[0m
e[31m2025-03-26 19:00:45.999 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] e[31m2025-03-26 19:00:45.999 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [281472553155408] Unexpected exception
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 245, in handle_call_service
response = await hass.services.async_call(
…<7 lines>…
File “/usr/src/homeassistant/homeassistant/core.py”, line 2794, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2837, in _execute_service
return await target(service_call)
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1007, in entity_service_call
single_response = await _handle_entity_call(
hass, entity, func, data, call.context
result = await task
s6-rc: info: service legacy-services: stopping
Found 2 non-daemonic threads.
[18:22:40] INFO: e[32mHome Assistant Core finish process exit code 0e[0m
[18:22:40] INFO: e[32mHome Assistant Core service shutdowne[0m
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun home-assistant (no readiness notification)
s6-rc: info: service legacy-services successfully started
e[31m2025-03-26 19:23:10.886 ERROR (MainThread) [homeassistant.config] Invalid config for ‘homeassistant’ at configuration.yaml, line 2: ‘pakete’ is an invalid option for ‘homeassistant’, check: paketee[0m
e[33m2025-03-26 19:23:10.886 WARNING (MainThread) [homeassistant.bootstrap] Unable to set up core integrations. Activating recovery modee[0m
e[33m2025-03-26 19:23:11.354 WARNING (MainThread) [homeassistant.components.home assistant OS.handler] e[33m2025-03-26 19:23:11.354 WARNING (MainThread) [homeassistant.components.home assistant OS.handler] Found incompatible HTTP option ‘server_host’. Watchdog feature disablede[0me[0m
e[33m2025-03-26 19:25:33.911 WARNING (MainThread) [homeassistant.helpers.translation] e[33m2025-03-26 19:25:33.911 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Integration ‘KNX’ not found.e[0me[0m
e[31m2025-03-26 19:29:22.722 ERROR (MainThread) [homeassistant.components.homeassistant] e[31m2025-03-26 19:29:22.722 ERROR (MainThread) [homeassistant.components.homeassistant] The system cannot reload because the configuration is not valid: Invalid config for ‘homeassistant’ at configuration.yaml, line 2: ‘pakete’ is an invalid option for ‘homeassistant’, check: paketee[0me[0m
e[31m2025-03-26 19:29:22.723 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] e[31m2025-03-26 19:29:22.723 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection] [281473044880048] Unexpected exception
…<7 lines>…
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 1110, in _async_admin_handler
await result
File “/usr/src/homeassistant/homeassistant/components/homeassistant/init.py”, line 355, in async_handle_reload_all
…<2 lines>…
homeassistant.exceptions.HomeAssistantError: Cannot quick reload all YAML configurations because the configuration is not valid: Invalid config for ‘homeassistant’ at configuration.yaml, line 2: ‘pakete’ is an invalid option for ‘homeassistant’, check: paketee[0me[0m
So, what you need is just to log in to your ha green and edit configuration.yaml file in the way that you put # on line 2.
You put “pakete” on line 2 and this is reason that ha can’t start as this is something it doesnt understand or exist.
I mean delete or put in front of “pakete” this # and then restart or reboot green.
Yes, restart or reboot it.
Reboot is running, I hope this was it
I Switch OFF the Power on HA Green and still starts , No Idea if this is normal.
Will send you a message about the satatus.
somehow, HA Green is not available over External access. No Idea what is here Wrong. Any Idea how to acess? Direct with Cable and IP adress?
Hello Again,
After I did the changes in and switched oFF the HA Green, I Can´t acesss it any more. I tried with remote acess and also locali over IP:8123, nothing works.
What can I do to get this thing to run again?
Hello Again,
I didnt ever use haos. This ha green is probably using haos.
I don’t know what you did.
You should use static ip address for your ha instance and set it up on router to use static ip for your ha green.
Check your router and look for connected clients. Maybe it changed ip address if it has dhcp for ha.
I Tried with static IP Adress bur same result. NO acess. I took this HA Green because it should be easy to use and set it up. some how I didn´t came Far
Look it is hard to start with the things you don’t understand. It takes time and effort to pick up some basic things.
This ha green probably have some Ethernet port. Connect it to your router reboot and it should give you ip address.
When you have ip address then you can connect to it using ip:8123.
Maybe for some reason ha didnt started and it doesnt listen to port 8123.
Maybe this device have open ssh port that you can use to connect to.
I don’t know as I never used that. Check online documentation for it.
As one guy once said there is no such a thing as a free lunch.
And this is the case. You will have to invest your time to it no matter green blue or yellow to get it going.
Can you attach a monitor and keyboard ?
192.168.0.61/22 is an unusual ip-address. What is the ip/netmask of the device you try to access your green ?
Perform a reset of your ha green using official troubleshooting doc.
You don’t show the netmask, but my guess is the ip of the green needs to be 192.168.0.61/24 and not /22
