Invalid config for [http]: [sensor] is an invalid option for [http]. Check: http->http->sensor. (See /config/configuration.yaml, line 21).
17:44:13 – (ERREUR) Home Assistant Supervisor
Unhandled exception
17:34:11 – (ERREUR) /usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py - message survenu pour la première fois à 4:17:07 et apparu 16 fois.
The ‘base_url’ option near /config/configuration.yaml:21 is deprecated, please remove it from your configuration
16:54:42 – (ATTENTION) HTTP - message survenu pour la première fois à 8:35:54 et apparu 46 fois.
Error reporting state - 5: Requested entity was not found.
7:18:14 – (ATTENTION) Home Assistant Cloud - message survenu pour la première fois à 4:24:10 et apparu 16 fois.
Failed to to call /network/interface/wlan0/update -
Valider votre configuration si vous avez récemment apporté des modifications à votre configuration et que vous souhaitez vous assurer que celle-ci est entièrement valide
Configuration invalideVÉRIFIER LA CONFIGURATION
Source: /usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py:393
First occurred: 19:51:52 (2 occurrences)
Last logged: 20:03:05
Unhandled exception
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1152, in _sendfile_fallback
read = await self.run_in_executor(None, file.readinto, view)
asyncio.exceptions.CancelledError
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 485, in start
resp, reset = await task
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 440, in _handle_request
reset = await self.finish_response(request, resp, start_time)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 591, in finish_response
await prepare_meth(request)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_fileresponse.py", line 241, in prepare
return await self._sendfile(request, fobj, offset, count)
File "/usr/local/lib/python3.8/site-packages/aiohttp/web_fileresponse.py", line 96, in _sendfile
await loop.sendfile(transport, fobj, offset, count)
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1131, in sendfile
return await self._sendfile_fallback(transport, file,
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 1161, in _sendfile_fallback
await proto.restore()
File "/usr/local/lib/python3.8/asyncio/base_events.py", line 263, in restore
self._transport.resume_reading()
File "/usr/local/lib/python3.8/asyncio/sslproto.py", line 344, in resume_reading
self._ssl_protocol._transport.resume_reading()
AttributeError: 'NoneType' object has no attribute 'resume_reading'
