I just got an Aeotech Mimote and am trying to figure out how to incorporate it in home assistant. I’ve setup an automation from the getting started guide without success. In OZWCP, the remote is shown. Maybe I just don’t understand how the zwave scenes work. Any guidance is appreciated.
Have you seen this: https://home-assistant.io/getting-started/z-wave-device-specific/ ? (bottom of the page).
The trigger part of each different button can be used in a automation rule i guess.
I just figured out how to get mine working;
First, follow the instructions in this thread - https://community.home-assistant.io/t/aeon-labs-minimote/1455/5
One exception to the thread I linked above is that the remote would never show as Scene Mode in OZWCP, even though I followed the instructions many times. If you followed the instructions correctly, it should be in Scene mode even if it doesn’t say that it is.
Next, set up your automations as the link in the post above me says.
Finally, in Home Assistant, call the zwave/add_node service and press the learn (or join) button on your Minimote. The Minimote should blink like it did when you initially included it in the z-wave network. After I did that, my Minimote has been working great!
