Hello World test package
I was creating a package to test and communicate some issues I am having.
I wanted something self contain that I could post and you guy could implement and test easily.
I thought I would create a input_select for the user to control some settings. Then a input_boolean for a virtual switch. A sensor based on the value of the input_boolean.
This is the test something that is not working in my automation calling python scripts (hello_world.py).
Right now, the switch and sensor works as expected, but the automation of just controlling the switch based on the input_select is not working. I think it is in my action. When I try and test in the developer tool-call service, it does not work. I need to get past this to demo my real world issue. :slight_smile:
I just am not seeing it.
Here is how I am calling devloper->service
Here is the entity
I can show it
FYI Current Package
input_select:
  test_hello_world_mode:
    name: Hello World Mode
    options:
      - "Off"
      - "Mode 2"
      - "Mode 3"
      - "Mode 4"
    icon: mdi:target
input_boolean:
  test_hello_world_switch:
    name: Hello World Switch
    initial: off
    icon: mdi:flashlight
group:
  test_hello_world_views:
    view: yes
    name: Test Hello World Script
    entities:
    - group.test_hello_world_script
  test_hello_world_script:
    entities:
    - input_select.test_hello_world_mode
    - input_boolean.test_hello_world_switch
    - sensor.hello_world_flashlight
  sensors:
    hello_world_flashlight:
      friendly_name: "Hello World Flashlight"
      value_template: >-
        {{ states.input_boolean.test_hello_world_switch.state }}
automation:
  - alias: test hello world script off
        value_template: "{% if is_state('test_hello_world_mode', 'off') %}true{% endif %}"
      - service: input_boolean.turn_off
        entity_id: input_boolean.test_hello_world_switch
  - alias: test hello world script on
        value_template: "{% if not is_state('test_hello_world_mode', 'off') %}true{% endif %}"
  # - alias: test hello world script off
    # trigger:
      # - platform: template
        # value_template: "{% if is_state('test_hello_world_mode', 'off') %}true{% endif %}"
    # action:
      # - service: python_script.hello_world
        # data_template:
          # name: "{{ trigger.to_state.state }}"
