Hi! I am trying to install home assistant via official helm chart, but when I set hostNetwork: true
and enable ingress all containers are in pending state saying:
Warning FailedScheduling <unknown> default-scheduler 0/1 nodes are available: 1 node(s) didn't have free ports for the requested pod ports
If I set hostNetwork: true, installation is fine and I am able to connect to home-assistant via created ingress resource for the main container. But without host network, home assistant does not see anything in my network (thats logical).
Any ideas how to fix this?
Also, there are no configuration examples for hass-configurator and vscode containers. What should be configured in ingress part for these components?
Hi! Thanks for the answer. I need hostNetwork to be able to discover devices in my home network. Problem with port is because I have clickhouse running on 8123 port. I tried to change port to 8124, but it does not help - hass cant start.
# Default values for home-assistant.
# This is a YAML-formatted file.
# Declare variables to be passed into your templates.
image:
repository: homeassistant/home-assistant
tag: 0.104.2
pullPolicy: IfNotPresent
pullSecrets: []
# upgrade strategy type (e.g. Recreate or RollingUpdate)
strategyType: Recreate
# Probes configuration
probes:
liveness:
enabled: true
initialDelaySeconds: 60
failureThreshold: 5
timeoutSeconds: 10
readiness:
enabled: true
failureThreshold: 5
timeoutSeconds: 10
startup:
enabled: false
failureThreshold: 30
periodSeconds: 10
service:
type: ClusterIP
port: 8123
annotations: {}
labels: {}
clusterIP: ""
## List of IP addresses at which the hass-configurator service is available
## Ref: https://kubernetes.io/docs/user-guide/services/#external-ips
externalIPs: []
loadBalancerIP: ""
loadBalancerSourceRanges: []
# nodePort: 30000
ingress:
enabled: true
annotations:
kubernetes.io/tls-acme: "true"
cert-manager.io/cluster-issuer: le-prod-ci
path: /
hosts:
- hass.domain
tls:
- secretName: home-assistant-tls
hosts:
- hass.domain
hostNetwork: false
persistence:
enabled: true
## home-assistant data Persistent Volume Storage Class
## If defined, storageClassName: <storageClass>
## If set to "-", storageClassName: "", which disables dynamic provisioning
## If undefined (the default) or set to null, no storageClassName spec is
## set, choosing the default provisioner. (gp2 on AWS, standard on
## GKE, AWS & OpenStack)
# storageClass: "-"
## If you want to reuse an existing claim, you can pass the name of the PVC using
## the existingClaim variable
# existingClaim: your-claim
## If you want to use a volume on the host machine instead of a PVC:
hostPath: /var/hass
accessMode: ReadWriteOnce
## Additional hass container environment variable
## For instance to add a http_proxy
extraEnv: {}
## Additional hass container environment variable from k8s secrets
## For instance to add a password
## can use `!env_var` in the home assistant configuration to reference these variables
extraEnvSecrets:
# Example
# This will set ${MQTT_PASSWORD} to the 'password' key from the 'mqtt' secret
# MQTT_PASSWORD:
# secret: mqtt
# key: password
# Enable pod security context (must be `true` if runAsUser or fsGroup are set)
usePodSecurityContext: true
# Set runAsUser to 1000 to let home-assistant run as non-root user 'hass' which exists in 'runningman84/alpine-homeassistant' docker image.
# When setting runAsUser to a different value than 0 also set fsGroup to the same value:
# runAsUser: <defaults to 0>
# fsGroup: <will be omitted in deployment if runAsUser is 0>
git:
enabled: false
## we just use the hass-configurator container image
## you can use any image which has git and openssh installed
image:
repository: causticlab/hass-configurator-docker
tag: 0.3.7-x86_64
## Specify the command that runs in the git-sync container to pull in configuration.
# command: []
# repo:
secret: git-creds
syncPath: /config
keyPath: /root/.ssh
zwave:
enabled: false
device: ttyACM0
# Mount devices or folders from the host machine. Can be used for USB device mounting.
hostMounts: []
# Example
# - name: zha
# hostPath: /dev/serial/by-id/usb-Silicon_Labs_HubZ_Smart_Home_Controller_6120245D-if01-port0
configurator:
enabled: true
## hass-configurator container image
image:
tag: 0.3.7-x86_64
## URL for the home assistant API endpoint
hassApiUrl: http://home-assistant.hass:8124/api/
## home assistant API password
# hassApiPassword:
## path where the home assistant configuration is stored
basepath: /config
## don't allow switching out of the base path
enforceBasepath: true
## username for basic auth for accessing the configurator
# username:
## password (sha256-hash) for basic auth for accessing the configurator
## For example "test" would be "{sha256}9f86d081884c7d659a2feaa0c55ad015a3bf4f1b2b0b822cd15d6c15b0f00a08"
# password:
## Additional hass-configurator container environment variable
extraEnv: {}
ingress:
enabled: true
annotations:
path: /configurator
hosts:
- hass.domain
tls:
hosts:
- hass.domain
service:
type: ClusterIP
port: 3218
annotations: {}
labels: {}
clusterIP: ""
externalIPs: []
loadBalancerIP: ""
# nodePort: 30000
## Add support for Prometheus
# settings has to be enabled in configuration.yaml
# https://www.home-assistant.io/components/prometheus/
monitoring:
enabled: false
serviceMonitor:
# When set true and if Prometheus Operator is installed then use a ServiceMonitor to configure scraping
enabled: true
# Set the namespace the ServiceMonitor should be deployed
# namespace: monitoring
# Set how frequently Prometheus should scrape
# interval: 30s
# Set path to beats-exporter telemtery-path
# telemetryPath: /metrics
# Set labels for the ServiceMonitor, use this to define your scrape label for Prometheus Operator
# labels:
vscode:
enabled: true
## code-server container image
image:
repository: codercom/code-server
tag: 2.1697-vsc1.39.2
## VSCode password
# password:
hassConfig: /config
## path where the VS Code data should reside
vscodePath: /config/.vscode
## Additional hass-vscode container environment variable
extraEnv: {}
ingress:
enabled: true
annotations:
path: /vscode
hosts:
- hass.domain
tls:
hosts:
- hass.domain
service:
type: ClusterIP
port: 80
annotations: {}
labels: {}
clusterIP: ""
## List of IP addresses at which the hass-vscode service is available
externalIPs: []
loadBalancerIP: ""
# nodePort: 30000
resources: {}
# We usually recommend not to specify default resources and to leave this as a conscious
# choice for the user. This also increases chances charts run on environments with little
# resources, such as Minikube. If you do want to specify resources, uncomment the following
# lines, adjust them as necessary, and remove the curly braces after 'resources:'.
# limits:
# cpu: 100m
# memory: 128Mi
# requests:
# cpu: 100m
# memory: 128Mi
nodeSelector: {}
tolerations: []
affinity: {}
podAnnotations: {}
# Any extra volumes to define for the pod
extraVolumes: []
# - name: example-name
# hostPath:
# path: /path/on/host
# type: DirectoryOrCreate
# Any extra volume mounts to define for the containers
extraVolumeMounts: []
# mountPath: /path/in/container
