Help a beginner - “Didn’t update - location update from the past”
Hi all!
I decided to restart my home assistant since I know have much more modern equipment that are able to connect to home assistant.
When I stopped I just unplugged everything. Now I have plugged everything back and for some reason getting this fault code. I have:
Reinstalled home assistant on the raspberry pi and deleted the app and downloaded it again. The fault code I’m getting is this:
“start_ssid” : “SKYNET v2”,
“event” : “ZoneManagerEvent(locationChange([<+55+12> +/- 1878.00m (speed -1.00 mps / course -1.00) @ 2023-12-06 kl. 18:17:24 centraleuropeisk normaltid]))”,
“error” : “locationUpdateTooOld”
Pleas advise on how I move on. Thank you all in advance.
I’m getting same error after the location update.
“start_ssid” : “xxxx",
“event” : “ZoneManagerEvent(locationChange([<+25.06719207,+55.20429611> +/- 1414.00m (speed -1.00 mps / course -1.00) @ 15/01/2024, 1:53:14 AM Gulf Standard Time]))”,
I have the same problem. I simply did an update, but now I’m getting this message:
“event” : “ZoneManagerEvent(locationChange([<+52.29492309,+5.14958307> +/- 94.93m (speed -1.00 mps / course -1.00) @ 10-01-2025, 19:15:59 Midden-Europese standaardtijd]))”,
“error” : “locationUpdateTooOld”,
“start_ssid” : “xxxx”
I have no idea what it means. Is the backup to install too old?
