Very simple setup seems complicated to program!
I’m very new to HA and YAML. Started 2 weeks ago.
I just can’t google a solution to this simple setup:
I have a TRV and a thermometer in the same room (SONOFF).
The TRV have the option for setting a offset.
I want the offset to be calculated by ThermometerTemp minus TRVTemp and have HA set the offset to this value.
These are the enitities and attributes for this:
‘sensor.termometer_temperature’ - The actual temperature on the thermometer
‘climate.termostat_1’,‘current_temperature’ - The temperature the TRV measures
‘number.termostat_1_local_temperature_calibration’ - The TRV offset
Don’t know if it needs some trigger or conditions. If it does, then it should run everytime ThermometerTemp is not equal to ThermostatTemp.
What do I need to insert in my YAML file to make this work?
TIA
