Help a noob. Automation template unknown error
Hi all. Please assist with the following. Not sure which part of this is incorrect. It must definitely be the conversion of a value somewhere but not sure which one.
{% set mode = states('input_select.regulator_mode') | lower%}
{% set power = states('input_select.regulator_power') | lower%}
{% set tempHeat = states('input_select.regulator_temp_heat')  %}
{% set tempCool = states('input_select.regulator_temp_cool')  %}
{% set time = states('input_select.regulator_speed') %}
{% set temperature = states('sensor.temperature_2') %}
{% set humidity = states('sensor.humidity_2') %}
{% if temperature < tempHeat %}
   {% if tempHeat - temperature <= '0.5' %}
      {% if power == 'Passive' %}
         script.regulator_heat_03
      {% elif power == 'Aggressive' %}
      {% endif %}
   {% elif tempHeat - temperature <= '1.0' %}
         script.regulator_heat_06
      {% endif %}
   {% elif tempHeat - temperature <= '1.5' %}
         script.regulator_heat_09
      {% endif %}
   {% elif tempHeat - temperature <= '2.5' %}
         script.regulator_heat_12
      {% endif %}
   {% elif tempHeat - temperature > '2.5' %}
      script.regulator_heat_15
   {% endif %}
{% elif temperature > tempCool %}
   {% if temperature - tempCool <= '0.5' %}
         script.regulator_cool_passive
         script.regulator_cool_low
      {% endif %}
   {% elif temperature - tempCool <= '1.0' %}
         script.regulator_cool_medium
      {% endif %}
   {% elif temperature - tempCool <= '1.5' %}
         script.regulator_cool_high
      {% endif %}
   {% elif temperature - tempCool <= '2.5' %}
      {% endif %}
   {% elif temperature - tempCool > '2.5' %}
      script.regulator_cool_high2
   {% endif %}
{% endif %}
The general way to debug something is to remove copy paste everything to notepad and remove everything from your template then add one line at the time (except the if else part) to the template tool in developer tools, and see when the error occurs.
Thank you for the tip. I did as you explained and found the error to be on line 2 of the sumarised code.
   {% endif %}
{% endif %}
“tempHeat - temperature” seems to be causing the issue.
It’s more likely that the problem is that you’re trying to do <= on a string I would think. Take the quotes off the numbers.
Thanks for the help i figured it out!
To anyone coming here for an answer: Doing it the following way works. Now i just need to figure out how to convert this to a service template to call the returned value as a service.
{% set mode = states('input_select.regulator_mode') %}
{% set power = states('input_select.regulator_power') %}
{% set tempvaldifLow = ( states('input_select.regulator_temp_heat') | float | round(1)) - ( states('sensor.temperature_2') | float | round(1)) %}
{% set tempvaldifHigh = ( states('sensor.temperature_2') | float | round(1)) - ( states('input_select.regulator_temp_cool') | float | round(1)) %}
   {% if tempvaldifLow <= 0.5 %}
      {% endif %}
   {% elif tempvaldifLow <= 1.0 %}
      {% endif %}
   {% elif tempvaldifLow <= 1.5 %}
      {% endif %}
   {% elif tempvaldifLow <= 2.5 %}
      {% endif %}
   {% elif tempvaldifLow > 2.5 %}
   {% endif %}
   {% if tempvaldifHigh <= '0.5' %}
      {% endif %}
   {% elif tempvaldifHigh <= '1.0' %}
      {% endif %}
   {% elif tempvaldifHigh <= '1.5' %}
      {% endif %}
   {% elif tempvaldifHigh <= '2.5' %}
      {% endif %}
   {% elif tempvaldifHigh > '2.5' %}
   {% endif %}
{% endif %}
