I’m using Hassio, I’ve installed AppDaemon, how I can install it from Hassio?
What steps did you made until now?
Did you followed some step by step tutorial?
I’ve installed the AppDaemon add-on from Hassio… now I need a step by step tutorial to install AlarmSystem…
I just downloaded code from https://gist.github.com/runningman84/b96a331b3486dbd1f5f2d00bc85d99ed
I copied alarm.py in appdaemon/addon and apps.yaml in config and added code in my configuration.yaml
in the apps.yaml file I will define my sensors
device_trackers: … i listed my phones
armed_home_sensors: what I will list? the sensors acivated when I’m at home? (windows sensors e.g.?)
armed_away_sensors: what I will list? the camera sensors? the main door?
alarm_control_buttons: the switches to arm/not arm the alarm?
and the others? how I will define them?
vacation_control: input_boolean.vacation_mode
guest_control: input_boolean.guest_mode
silent_control: input_boolean.silent_mode
alarm_volume_control: input_number.xiaomi_alarm_volume
info_volume_control: input_number.xiaomi_info_volume
I need some suggestions… please
Ciao Andrea @andyinno Auguri di Buon Anno!!!
Ciao vpomax, buon anno anche a te
in device_trackers you can list the devices that you want to track home / not home.
If you put devices there you can have the alarm auto activated when all the phones are away.
armed_home_sensors: I put there all the peripheral sensors. For example the Door / Window sensor from xiaomi
armed_away_sensors: I put there all the sensors from armed_home_sensors plus the PIR sensors I have at home
alarm_control_bttons are some switches. I am using one like this one:
https://www.gearbest.com/smart-light-bulb/pp_257679.html
It gives you single press, long press, double click.
Single click is mapped to alarm home
double click is mapped to disarm
long press is mapped to alarm away
I didn’t define any of the other. but you can if you need them.
From the comment in the first thread I linked to you vacation_control is not active. It is just a placeholder so you can ignore it.
Hi @andyinno ok… I wrote so…in apps.yaml
alarm_system:
module: alarm
class: AlarmSystem
device_trackers:
- device_tracker.samsng_s8_wifi
- device_tracker.samsung_s8_bt
armed_home_sensors:
- binary_sensor.door_window_sensor_aaaaaaaa
- binary_sensor.door_window_sensor_bbbbbbbb
- binary_sensor.door_window_sensor_ccccccccc
- binary_sensor.door_window_sensor_dddddddd
- binary_sensor.door_window_sensor_eeeeeeee
- binary_sensor.door_window_sensor_fffffffffff
armed_away_sensors:
- binary_sensor.motion_sensor_ggggggggg
- binary_sensor.motion_sensor_hhhhhhhhh
- binary_sensor.motion_sensor_iiiiiiiiiiiii
- binary_sensor.motion_sensor_jjjjjjjjjjjj
- binary_sensor.switch_xxxxxxxxxx
alarm_lights:
- light.gateway_light_yyyyyyyyyyy
alarm_pin: !secrets alarm_pin
xiaomi_aqara_gw_mac: zzzzzzzzzzzzz
notify_service: script/send_status_report_bob
notify_title: "Intruder Alert"
Is it all right?
the row
call a script? which script?
looks almost good to me.
I placed the door/window sensors also in armed_away_sensors with the motion sensor.
They are duplicated.
Differences from my setup:
device_trackers:
- group.person_A
- group.person_B
- group.person_C
remember the group setting I told you in the other thread?
as notify_service I set up smtp that sends an email when it detects movement / door - windows open.
notify_service: notify/gmail
For sending email from home assistant I had to add a body to the email otherwise it is not sent.
I just edited the code from the title adding the same text for the body.
What kind of notification service do you plan to use?
I didn’t use volume_control and other settings. the default values in the python script worked for me.
may I delete these rows?
I wish to use gmail too for notificatons
I inserted these lines in confguration.yaml
notify:
- name: HASSIO
platform: smtp
server: smtp.gmail.com
port: 587
timeout: 15
sender: [email protected]
encryption: starttls
username: [email protected]
password: xxxxxxxxxxxx
recipient:
- [email protected]
- [email protected]
sender_name: My Home Assistant
and then what I write in apps.yaml? instead of
notify_service: notify.HASSIO
I would suggest you to create a simple script and call the notify_service there. Right now the AlarmSystem just calls any “service” but it does not send custom arguments like email subject, email content and so on.
Any suggestion to create a script?
Can you report me a script example to use with gmail SMPT?
yes this is my current script:
Thanks… you script.yaml file is too complicated for me and have many calls.
At the moment I wish to begin with a more simple script that send me a message when system is armed, when system is disarmed and when system detect and intruder and s in alert.
you can strip it down to to this minimal example:
Thank you @runningman84bt your script is too coplicated for me.
I’m a newbie, for a first step I wish a script that send me a message when Systemalarm is armed, is disarmed, and when it detect an intrusion (alarmed)
my apps.yaml contain…
notify_service: notify.hassio
then in my confguration.yaml I have…
notify:
- name: hassio
platform: smtp
port: 587
timeout: 15
starttls: 1
password: !secret email_password
recipient: [email protected]
and in automation:
- alias: Notifica SystemAlarm
platform: state
entity_id: alarm_control_panel.ha_alarm
to: 'triggered'
title: SystemAlarm
message: 'Allarme Home attivato'
target: 'aaaaabbbbb@gmailcom'
Now this works fine… but I receive the mail about 10/20 seconds after it happens
My scripts.yaml do not works, it do not send any message… WHAT IS WRONG?
notify:
- name: hassio
platform: smtp
port: 587
timeout: 15
starttls: 1
username:[email protected]
in scripts.yaml
send_status_report:
alias: "Send status report"
sequence:
- service: notify.hassio
data_template:
title: "AlertSystem triggered"
message: {{ states('alarm_control_panel.ha_alarm') }}
Does it work now?
I moved the app from gist to a normal github repo:
