After updating to version 2022.6.7 my HA stopped accessing, but apparently it is there, with the following happening:
When starting the VM it starts normally, but it informs an address a little different from what it was previously.
Before: https://homeassistant.local:8123 and https://homeassistant.local:4357
Now: http://homeassistantxx.local:8123 and http://homeassistantxx.local:4357 -
Through the observer’s address (http://homeassistantxx.local:4357) it informs that the HA has normal access.
No longer access via: https://homeassistant.local:8123 (I use Duckdns) nor via http://homeassistant.local:8123
Does not access https://homeassistantxx.local:8123 or http://homeassistantxx.local:8123
Does not access via IP: https://192.168.xxx.xxx:8123 or http://192.168.xxx.xxx:8123
If I remove port 8123 it seems to start, but then it reports an access error.
Strangely, Node-Red accesses: https://192.168.xxx.xxx:1880, but without recognizing the Home Assistant entities.
So I know my HA is still there, but something has changed the address or something that it doesn’t let me access anymore.
Note: I no longer have a backup of the previous installation, so I need to access this installation.
Please help me!
