Hi everyone,
I’m struggling to regain access to host ssh server on hassio.
I had it configured in the past, and it suddenly stopped working, I suspect with some update of the core system.
Now I’m dedicating time to regain access but I seem to be unsuccessful in doing so.
So far I’ve tried to:
- Import files from Supervisor > System > Host System, from a USB key called labelled CONFIG that holds just the
authorized_keys
files with my public key in it. - Manually editing the
/root/.ssh/authorized_keys
file on the hassio overlay partition, mounting the SD directly on my system
None of the activities worked and I’m out of ideas. I’ve already checked the permissions on both /root/.ssh
and /root/.ssh/authorized
keys and they are as expected
What else should I check? Or is there a way to reinitialize this? Maybe if I manually delete files and folder and then force a new import?
thank you
