I’ve been trying to figure this out for quite a while now, but I can’t find a solution. I purchased the following LED strips not knowing they would be so difficult to set up:
I have no idea what LED controller to use with these to get them into Home Assistant. I’ve posted on Reddit in both the HA and WLED subs, and I’ve asked in the HA discord, and nobody seems to know what I should get…
The Amazon page lists seven different controllers “sold separately”. As @Nick4 says, you need to find an integration for one of them. There’s a list here:
At this point I’d be fine with any integration. I don’t care which one, I just want one that works with HA! I’ve been looking around and I can’t find any at all.
Sadly, Amazon is often wrong about these sort of things. When I first ordered the strips, I also ordered one of those controllers, both because Amazon suggested it and because it SEEMED like the right one with a little research.
Within a few hours, I got a seller message through Amazon directly from BTF lighting, saying “hey we saw you ordered these strips and that controller, but they won’t work together.”
They suggested the single controller that they sell that works with that strip. It’s bluetooth, so I can controll it from my phone, but not with anything else.
If I hadn’t already gone through all the trouble of installing these strips, I’d return them and get another more compatible model, but they work really well for what I need and I really would like to make it work. Otherwise I’ll just stick them into a smart plug and live with basic on/off functionality.
Hmm…looks like WLED supports it, but just as a single color? I’m not sure I’m reading that right… I’m still not sure what hardware to get though. I ordered some Digi-quad controllers because someone on Reddit said they’d used those and gotten them to work. I’ll see if I have the same luck.
