I’ve finally got my Silicon Labs UZB-7 updated to the latest firmware and connected it to my HA USB Hub
I’ve installed Zwave JS addon, and it has successfully detected my controller (I let it generate all it’s own keys etc)
Everything looks good in the Network page
However, I have now tried adding two different devices - TKB Plug (instructions) and a NeoCoolcam Motion sensor, and neither seem to connect. Both are plugged in / held right next to the stick so distance is not at fault
I have followed the instructions, reset them both (as far as I am able to tell - at least in so far as they are no longer controllable by the old hub) yet entering them into pairing mode seems to do nothing
How can I work out what is going on and how to repair?
EDIT: Just found the log page and set to debug:
Log Level changed to: Debug
2022-08-24T12:03:12.122Z CNTRLR Starting inclusion process with strategy Default...
2022-08-24T12:03:12.149Z SERIAL » 0x0105004XXXXXXX (7 bytes)
2022-08-24T12:03:12.157Z DRIVER » [REQ] [AddNodeToNetwork]
node type: Any
high power: true
network wide: true
callback id: 17
2022-08-24T12:03:12.165Z SERIAL « [ACK] (0x06)
2022-08-24T12:03:12.173Z SERIAL « 0x0107004a110YYYYYYY (9 bytes)
2022-08-24T12:03:12.176Z SERIAL » [ACK] (0x06)
2022-08-24T12:03:12.180Z DRIVER « [REQ] [AddNodeToNetwork]
status: Ready
callback id: 17
2022-08-24T12:03:12.204Z CNTRLR The controller is now ready to add nodes
