hi,
I upgraded to the current version from 0.46. and the GUI does not come up.
anyone can help?
pi@hassbian:~ $ sudo systemctl status [email protected] -l
â [email protected] - Home Assistant for homeassistant
Loaded: loaded (/etc/systemd/system/[email protected]; enabled)
Active: active (running) since Thu 2017-08-03 15:55:14 UTC; 2min 38s ago
Main PID: 719 (hass)
CGroup: /system.slice/system-home\x2dassistant.slice/[email protected]
ââ 719 /srv/homeassistant/bin/python3 /srv/homeassistant/bin/hass
ââ 778 /srv/homeassistant/bin/python3 -m pip install --quiet python_openzwave==0.4.0.31 --upgrade --constraint /srv/homeassistant/lib/python3.4/site-packages/homeassistant/package_constraints.txt
ââ 795 /srv/homeassistant/bin/python3 -u -c import setuptools, tokenize;file=’/tmp/pip-build-naul5_6d/python-openzwave/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’)) install --record /tmp/pip-eg7v0hc7-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.4/python-openzwave
ââ 814 make
ââ 832 /bin/sh -c LDFLAGS="" CPPFLAGS="" make -C /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/build/ -
ââ 833 make -C /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/build/ -
ââ1319 /bin/sh -c g++ -c -Wall -Wno-unknown-pragmas -Werror -Wno-format -Wno-error=sequence-point -Wno-sequence-point -O3 -DNDEBUG -fPIC -DSYSCONFDIR=""/usr/local/etc/openzwave/"" -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/src -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/tinyxml/ -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/hidapi/hidapi/ -o /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/.lib/SensorAlarm.o /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/src/command_classes/SensorAlarm.cpp
ââ1320 g++ -c -Wall -Wno-unknown-pragmas -Werror -Wno-format -Wno-error=sequence-point -Wno-sequence-point -O3 -DNDEBUG -fPIC -DSYSCONFDIR="/usr/local/etc/openzwave/" -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/src -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/tinyxml/ -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/hidapi/hidapi/ -o /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/.lib/SensorAlarm.o /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/src/command_classes/SensorAlarm.cpp
ââ1321 /usr/lib/gcc/arm-linux-gnueabihf/4.9/cc1plus -quiet -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/src -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/tinyxml/ -I /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/hidapi/hidapi/ -imultilib . -imultiarch arm-linux-gnueabihf -D_GNU_SOURCE -D NDEBUG -D SYSCONFDIR="/usr/local/etc/openzwave/" /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/cpp/src/command_classes/SensorAlarm.cpp -quiet -dumpbase SensorAlarm.cpp -march=armv6 -mfloat-abi=hard -mfpu=vfp -mtls-dialect=gnu -auxbase-strip /tmp/pip-build-naul5_6d/python-openzwave/openzwave-embed/open-zwave-master/.lib/SensorAlarm.o -O3 -Wall -Wno-unknown-pragmas -Werror -Wformat=0 -Wno-error=sequence-point -Wno-sequence-point -fPIC -o /tmp/cc4aslaq.s
Aug 03 15:55:49 hassbian hass[719]: INFO:homeassistant.setup:Setting up emulated_hue
Aug 03 15:55:49 hassbian hass[719]: WARNING:homeassistant.components.emulated_hue:Listen IP address not specified, auto-detected address is 10.10.1.116
Aug 03 15:55:49 hassbian hass[719]: WARNING:homeassistant.components.emulated_hue:When targetting Google Home, listening port has to be port 80
Aug 03 15:55:49 hassbian hass[719]: INFO:homeassistant.setup:Setup of domain emulated_hue took 0.0 seconds.
Aug 03 15:55:49 hassbian hass[719]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=emulated_hue>
Aug 03 15:55:49 hassbian hass[719]: INFO:homeassistant.util.package:Attempting install of python_openzwave==0.4.0.31
Aug 03 15:55:49 hassbian hass[719]: WARNING:homeassistant.setup:Setup of camera is taking over 10 seconds.
Aug 03 15:55:49 hassbian hass[719]: INFO:homeassistant.setup:Setup of domain arlo took 0.8 seconds.
Aug 03 15:55:49 hassbian hass[719]: INFO:homeassistant.core:Bus:Handling <Event component_loaded[L]: component=arlo>
Aug 03 15:55:50 hassbian hass[719]: WARNING:homeassistant.setup:Setup of device_tracker is taking over 10 seconds.
thanks,
