Hi all, i’m back with a strange problem.
Since yesterday all automations on my HA does’n fire.
I have time trigger and Sun trigger.
It seems nothing changed, but does not run more.
Until yesterday all works fine
@nickrout, as I wrote they are all activated, i.e. on in dev-state.
Below is one example of non-firing automations, this one is intended to catch state changes of my Nexa 433-remotes and control all my lights. (i have a firly complex mix of Zigbee, Z-wave and 433 Mhz devices)
As you can see it is a very simple trigger and there is no reason for it not to fire (as long as the automation is active)
# Generic script to handle Nexa remote events
# Remotes are represented as switches with one switch per button
# Each button needs to have a group with the same name as the switch, i.e. switch.remote1 and group.remote1
# NOTE: "Global" buttons only functions as button nr 1 as the "group" attribute is not available in HA.
- id: 'Nexa remotes'
alias: Nexa fjärrkontroller
- platform: state
entity_id:
- switch.remote_carl1
- switch.remote_carl2
- switch.remote_carl3
- switch.remote_ellinor1
- switch.remote_ellinor2
- switch.remote_ellinor3
- switch.remote_kontor1
- switch.remote_kontor2
- switch.remote_kontor3
- switch.remote_nils1
- switch.remote_nils2
- switch.remote_nils3
- switch.remote_ovrehall1
- switch.remote_ovrehall2
- switch.remote_ovrehall3
- switch.remote_sovrum1
- switch.remote_sovrum2
- switch.remote_sovrum3
- switch.remote_test1
- switch.remote_test2
- switch.remote_test3
- switch.remote_vardagsrum1
- switch.remote_vardagsrum2
- switch.remote_vardagsrum3
- switch.remoteknapp_carl1
- switch.remoteknapp_carl2
- switch.remoteknapp_nils1
- switch.remoteknapp_nils2
- switch.remoteknapp_vardagsrum1
- switch.remoteknapp_vardagsrum2
service_template: >
{% if trigger.to_state.state == "on" %}
homeassistant.turn_on
{% else %}
homeassistant.turn_off
{% endif %}
data_template:
entity_id: >
group.{{ trigger.to_state.object_id }}
I just tried upgrading to 0.85.1 and, sure enough, the automation triggers stop working.
Downgrading to 0.84.6 makes triggers fire again.
Exactly the same configuration and automation states!
