They still exists as entities but illuminance stays at 1.0 and motion is not detected. I can’t think of any change I’ve made having caused this mainly because the only changes where to my HACs integration and not related to ZigBee.
I’m using ZHA on the Home Assistant Blue with a ZZH stick.
Home Assistant OS 5.12
supervisor-2021.03.9
core-2021.3.4
I’ve tried everything I can think of and I’ve had no joy at all. I’m starting to wonder if the problem is with the ZZH stick but i’ve not had it very long at all and it’s only these devices
It’s pretty frustrating as i have a lot of automations based on these devices so any help will be massively appreciated.
Here is what i’ve tried so far:
Re-pairing the devices
Replaced device batteries
Restored HA to last known working state (yesterday morning)
Deleted and reinstalled ZHA integration
Added a completely new device into the network
Hoping you can help me Jamie. I’m just starting to set up the Zigbee network and have a ConBee II gateway and I am using the ZHA integration on Rasberry Pi 4 with HA OS 5.13, Supervisor 2021.04.3, and Core 2021.5.5.
I connected 2 Sonoff SNZB-03 motion sensors successfully this morning. But now I cannot add any more of the same sensors, nor can I add Aqara Motion Sensor.
I read that there is an issue with ConBee II close to USB3 and SSD devices. I have installed my Pi 4 in an Argon One M.2 case with a SATA SSD drive which uses a USB3 port, so lots of interference. I bought a 5m USB extension cable and now everything works perfectly.
Hi Miles, thanks for your post.
I had the issue.
I was running HA on a pi4 wt 8gb and all was fine with my cc2531 working like a charm.
Then one morning decided to overhaul the pi board into the argon m2 add the a wd blue 250 and and of I went. Took a snapshot installed HA reloaded the snapshot and all was working except my cc2531 and its 30 odd devices listening to it.
I ended up getting the pi case out again and connecting everything back to what it was.
Reading your post gets me confused a little as the same cc2531 is connected to the pi board and without any issue. Is it the interference with the ssd then?
