After HACS moved appdaemon into a0d7b954_appdaemon, I have problems with location of the logs files. Since all the rest of appdaemon is no longer inside the homeassistant directory, I would like to have the log files in a folder located together with the appdaemon stuff.
But I can not get this to work. Below is a part of my appdaemon.yaml. Everything is working as long as the path is inside the homeassistant/appdaemon folder. Is it possible to get it inside a0d7b954_appdaemon (together with the rest of appdaemon)
logs:
error_log:
filename: /homeassistant/appdaemon/logs/error.log
