Help, aqara door sensor
Hi
I need to extend with wires the magnetic touch for the aqara door sensor
Does someone know where I should place the wires in order to activate open-close with a magnet and the wires? (and not through the actual touch of the magnet to the sensor)
Inside I have this
The magnetic sensor is the glass tube on the right; it’s called a reed switch. You can de-solder the switch and solder the wires to the pads on te main-board.
Yes I’ve been meaning to do the for our bay window to save money.
Im going to purchase https://www.amazon.co.uk/sourcing-map-Magnetic-Security-Normally/dp/B00PZMG980/ref=sr_1_34?keywords=door+switch&qid=1581844598&sr=8-34 solder them in series and then connect the loose two ends to the two points left after the glass tube has been removed.
It wont tell me which window is open, it will just say the bay windows are open or trigger an alarm if any of the bay windows are opened.
nice idea!
@Robbo thanks!
