I found a code in the web explaining how to implement the calibration of the ph probe. It worked… Then I tried to do the same with the ec probe. But all I tried untill now did not work. I have the k 0.1 probe. I don’t get how to get the comands for the working ph calibration, because in the datasheet it looks a bit diferent. I would be very happy if there is someone who can help me.
# PH Sonde kalibrieren
name: "G1 pH clear calibration"
on_press:
then:
- lambda: |-
id(phg1_ezo).clear_calibration();
name: "G1 pH Calibration 7.00"
on_press:
then:
- lambda: |-
id(phg1_ezo).set_calibration_point_mid(7.00);
name: "G1 pH Calibration 4.00"
on_press:
then:
- lambda: |-
id(phg1_ezo).set_calibration_point_low(4.00);
name: "G1 pH Calibration 10.00"
on_press:
then:
- lambda: |-
id(phg1_ezo).set_calibration_point_high(10.00);
name: "G1 pH verify calibration"
on_press:
then:
- lambda: |-
id(phg1_ezo).send_custom("Cal,?");
# EC Sonde kalibieren
name: "G1 EC Clear Calibration"
on_press:
then:
- lambda: |-
id(ecg1_ezo).clear_calibration();
name: "G1 EC Set Probe Type K 0.1"
on_press:
then:
- lambda: |-
id(ecg1_ezo).send_custom("ec:k,0.1");
name: "G1 EC Calibration Dry"
on_press:
then:
- lambda: |-
id(ecg1_ezo).send_custom("Cal,dry");
name: "G1 EC Low Point Calibration"
on_press:
then:
- lambda: |-
id(ecg1_ezo).send_custom("Cal,low,84");
name: "G1 EC High Point Calibration"
on_press:
then:
- lambda: |-
id(ecg1_ezo).send_custom("Cal,high,1413");
