Help automation
I’m trying to turn off my pi
My script did work, but now it stopped.
Can some one help me to make it work again?
I think some update bricked my script, i am lost in fixing it.
I validate all the switches, sensors and links they are all fine.
platform: template
switches:
  switch_ender3_pi:
    friendly_name: 'Ender3 Killer'
    value_template: "{{ is_state('binary_sensor.ping_ender3_pi', 'on') }}"
    turn_on:
      service: switch.energy_temp_relay_2
    turn_off:
      data_template:
        entity_id: >
          {% if is_state('binary_sensor.ping_ender3_pi', 'on') %}
            url: "http://xx.xx.xx.xx:2345?KillThisPi"
            delay: '00:00:30'
            entity_id: switch.energy_temp_relay_2
          {% else %}
          {% endif %}
That’s surprising because this Template Switch is invalid:
  • turn_on contains an invalid service and no entity_id.
  • turn_off contains an entity_id but no service.
See the documentation for an example of a properly configured Template Switch.
I’ve been trying different things.
Got turn on working, that was easy.
But i cannot get the turn_off to work
I got this now
platform: template
switches:
  switch_ender3_pi:
    turn_on:
      service: switch.turn_on
    turn_off:
      service_template: >
            script.script_kill_ender3
          {% else %}
            script.script_pwr_ender_off
          {% endif %}
Scripts are
script_kill_ender3:
    sequence:
      # This is written using the Script Syntax
      - service: rest_command.ender3_pi_request
      - wait_template: "{{ is_state('binary_sensor.ping_ender3_pi', 'off') }}"
      - delay: '00:01:00'
      - service: switch.turn_off
        entity_id: switch.energy_temp_relay_3
script_pwr_ender_off:
    sequence:
I’m on it for days now and cannot get it to work.
Where am i going wrong?
The indenting is incorrect. Your scripts are not following the standard of using two spaces to indent a line. Look at the examples in the Script documentation and you’ll see everything is neatly indented by two spaces.
none still nothing, i’m really lost here
I think i have all indents correct now
platform: template
switches:
  switch_ender3_pi:
    turn_on:
    turn_off:
      service_template: >
        {% else %}
        {% endif %}
script_kill_ender3:
  sequence:
    - delay: '00:01:00'
  sequence:
Do the two scripts work if you call them manually from the Services page?
in services i can run them all and they work.
now only the automation has to play along.
For the life of me i can not get this to work!
    turn_off:
      service: script.turn_on
      data_template:
        entity_id: >
          {% else %}
          {% endif %}
in this code
platform: template
switches:
  switch_ender3_pi:
    turn_on:
    turn_off:
      data_template:
        entity_id: >
          {% else %}
          {% endif %}
