Help. Background is only white or black
i have an issue with my background for all dashboards for about 3 weeks. I use the IOS Themes from Hacs. It worked fine. When I changed the themes the background would also change. But suddenly it stopped working. I think after I startet using custom button cards or bubble cards or card-mod. But I’m not sure if those caused it. I tried manually uploading a background in to the www folder and adding it in the raw configurator, but it also didn’t work. I also tried installing other themes but those are also not working. The themes that are installed through hacs are located in themes.yaml. I also tried moving them to the www folder, but it didn’t work and I moved them back.
Does anybody know the reason?
I’d start by looking for filter: grayscale(100%);` in your theme or lovelace code
I tried looking for something but couldn’t find anything like it.
