Help Blueprints are driving me mad! - extra keys not allowed [in condition] Got None required key not provided [entity id]. Got None
Hey Folks,
I’m trying to write my first Blueprint to make it easier to roll out soft shutdown on my metered smart sockets.
I’m being plagued with this error:
extra keys not allowed @ data['condition'][1]['target']. Got None required key not provided @ data['condition'][1]['entity_id']. Got None
Here is the code of my Blueprint:
blueprint:
  name: Auto Power-Off Smart Socket
  domain: automation
  input:
    start_time:
      description: "The time from which you would like the switch to be automatically turned off."
      selector:
        time:
    end_time:
      selector:
        time:
    power_sensor:
      selector:
          entity:
            domain: sensor
            device_class: power
    power_switch:
      selector:
          entity:
            domain: switch
  - platform: numeric_state
    entity_id: !input power_sensor
    for:
      hours: 0
      minutes: 5
      seconds: 0
    below: 5
  - platform: time
    at: !input start_time
condition:
  - condition: time
    before: !input end_time
    after: !input start_time
  - condition: numeric_state
    target: !input power_sensor
    below: 5
  - service: switch.turn_off
    target: !input power_switch
And here is the code of my Automation:
alias: Auto Power-Off Smart Socket
description: ""
use_blueprint:
  path: auto_poweroff_smart_sock.yaml
  input:
    end_time: "00:00:00"
    start_time: "06:00:00"
    power_sensor:
      entity_id: sensor.attic_entertainment_power
    power_switch:
      entity_id: switch.attic_entertainment
I found a solution! Removing the target: part of my power_sensor and power_switch input declarations.
Credit to this suggestion on a similar post.
I’ll test some more and then post my finished blueprint.
I believe more is involved than merely “removing” target. The example you posted doesn’t use a State Condition and service call correctly (i.e. contains syntax errors). entity_id is the correct option name.
condition:
  - condition: time
    entity_id: !input power_sensor  # <--- entity_id not target
    below: 5
    entity_id: !input power_switch  # <--- entity_id not target
Alternative:
Here is my “finished” blueprint. It’s still a bit rough and ready but it it works.
Ideally it would take the timeout and power shutdown threshold as inputs and turn the socket back on at it’s end time.
blueprint:
  domain: automation
  input:
    start_time:
      selector:
        time:
    end_time:
      description: "The time to stop auto shutdown of the switch. Maybe when you plan to turn it on with another automation."
      selector:
        time:
    power_sensor:
      description: "The power sensor for your energy monitoring smart socket."
      selector:
        entity:
          domain: sensor
          device_class: power
    power_switch:
      description: "The switch control for your energy monitoring smart socket."
      selector:
        entity:
          domain: switch
    entity_id: !input "power_sensor"
    for:
      hours: 0
      minutes: 5
      seconds: 0
    below: 5
  - platform: time
    at: !input "start_time"
condition:
  - condition: and
    conditions:
    - condition: time
      before: !input "end_time"
      after: !input "start_time"
      below: 5
    entity_id: !input "power_switch"
mode: single
Ah so that’s how you make the targets actually work!
