Help by a motion sensor automation
ello everyone
i have an automation for my stair lighting based on my motion detectors.
However, I have a problem with this, namely the light on stairs 1 / 2 does not go out again if, for example, only BM1 is activated and BM2 is not.
it stops every time at the timeout of 1 minute, so I would have to set a condition beforehand and see if BM1 / BM2 have no more movement and then switch off the stairs again.
I tried to write the shutdown at the end of the automation but that never works because the timeout above then stops directly.
(pl_wipe_up = 1st stair on)
(pl_wipe_down = 1st stair off)
(pl_stair2_wipe_up = 2nd stair on)
(pl_stair2_wipe_down = 2nd stair off)
Maybe someone can help me there?
and my automation:
alias: >-
  Treppenbeleuchtung - Wipe Effekt  #################    WIP
description: ''
  - type: motion
    platform: device
    device_id: 0d55531630d0956068cbe251d38cf540
    entity_id: binary_sensor.hue_motion_sensor_1_motion
    domain: binary_sensor
  - type: motion
    platform: device
    device_id: af7049057675aaad0ce981dc433064b5
    entity_id: binary_sensor.hue_motion_sensor_2_motion
  - type: motion
    platform: device
    device_id: e2a31164d58c1f6b1c20de882398aa2d
    entity_id: binary_sensor.motion_sensor
condition: []
  - choose:
      - conditions:
          - condition: trigger
        sequence:
          - service: select.select_option
              entity_id: select.wled_playlist
              option: pl_wipe_up
          - wait_for_trigger:
              - platform: state
                entity_id:
                  - binary_sensor.motion_sensor
                to: 'on'
            timeout: '00:01:00'
            continue_on_timeout: false
              entity_id: select.wled_stair2_playlist
              option: pl_stair2_wipe_up
              option: pl_wipe_down
          - wait_for_trigger:
              - platform: state
                entity_id:
                  - binary_sensor.hue_motion_sensor_2_motion
                to: 'on'
            timeout: '00:01:00'
              option: pl_stair2_wipe_down
          - delay:
              hours: 0
              minutes: 0
              seconds: 5
              milliseconds: 0
      - conditions:
        sequence:
          - wait_for_trigger:
              - platform: state
                entity_id:
                to: 'on'
            timeout: '00:01:00'
              option: pl_wipe_up
          - wait_for_trigger:
              - platform: state
                entity_id:
                  - binary_sensor.hue_motion_sensor_1_motion
                to: 'on'
            timeout: '00:01:00'
          - delay:
              hours: 0
              minutes: 0
              seconds: 5
              milliseconds: 0
    default: []
mode: single
