Help: Cannot install additional blueprints, Unknown Error with Websocket API
I recently installed Home Assistant OS 8.2 on an Odroid-C4, and I have not been able to figure out the following issue.
Every time I try to import a blueprint from the Blueprint Exchange, I get “unknown error” on the dialog.
Checking the logs, it appears to be a WebSocket issue. Any ideas?
Logger: homeassistant.components.websocket_api.http.connection
Source: components/blueprint/importer.py:183
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: July 2, 2022, 8:06:50 AM (2 occurrences)
Last logged: 8:16:06 PM
[281472635377600] Error handling message: Unknown error (unknown_error)
[281472627967504] Error handling message: Unknown error (unknown_error)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1154, in _create_direct_connection
    hosts = await asyncio.shield(host_resolved)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 880, in _resolve_host
    addrs = await self._resolver.resolve(host, port, family=self._family)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/resolver.py", line 33, in resolve
    infos = await self._loop.getaddrinfo(
  File "/usr/local/lib/python3.9/asyncio/base_events.py", line 861, in getaddrinfo
    return await self.run_in_executor(
  File "/usr/local/lib/python3.9/concurrent/futures/thread.py", line 58, in run
  File "/usr/local/lib/python3.9/socket.py", line 954, in getaddrinfo
    for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
socket.gaierror: [Errno -3] Try again
  File "/usr/src/homeassistant/homeassistant/components/websocket_api/decorators.py", line 27, in _handle_async_response
    await func(hass, connection, msg)
  File "/usr/src/homeassistant/homeassistant/components/blueprint/websocket_api.py", line 68, in ws_import_blueprint
    imported_blueprint = await importer.fetch_blueprint_from_url(hass, msg["url"])
  File "/usr/src/homeassistant/homeassistant/components/blueprint/importer.py", line 225, in fetch_blueprint_from_url
    imported_bp = await func(hass, url)
  File "/usr/src/homeassistant/homeassistant/components/blueprint/importer.py", line 183, in fetch_blueprint_from_github_gist_url
    resp = await session.get(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client.py", line 535, in _request
    conn = await self._connector.connect(
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 542, in connect
    proto = await self._create_connection(req, traces, timeout)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 907, in _create_connection
    _, proto = await self._create_direct_connection(req, traces, timeout)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/connector.py", line 1166, in _create_direct_connection
    raise ClientConnectorError(req.connection_key, exc) from exc
aiohttp.client_exceptions.ClientConnectorError: Cannot connect to host api.github.com:443 ssl:default [Try again]
I have exactly the same problem. Where you able to solve this one?
So you are also running
This is most likely a problem with the ‘My’ integration not having the correct URL to get to your instance or something.
