I got “404: Not found” after installing the homeassistant.
Anyone can see where my problem is?
Thanks a lot!
I installed home assistant on the NAS(Synology) using method 2 on this page:
https://home-assistant.io/docs/installation/synology/
the process went fine, but at the end I cannot reach the webpage:
This is my log:
this is my configuration.yaml:
These are the files in the homeassistant folder:
