I’ve had my hassio running on my rpi4 for a few years now. Everything has worked great, until a month or two ago (had a hiatus from it). I’ve had duckdns and letsencrypt working too. I now have these symptoms:
Symptoms
Can no longer access via my duckdns url. I get the “Unable to connect to Home Assistant.” message.
Sometimes it takes a really long time to connect via my internal URL. Especially after rebooting.
Cannot connect with the HA app (with either internal IP or duckdns url)
I can SSH into HA. When I run “ha host reboot” I get an error message “Client.Timeout exceeded while awaiting headers.”
I’m now able to connect via duckdns url but not internal IP. What’s interesting is if I try to open ha on a new tab, that doesn’t work, but the original tab still fully functional. Additionally, HA is still “starting” hours later.
This may be my issue here.
22-10-21 14:52:35 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/ad0058c0.tar: unexpected end of data
22-10-21 14:52:36 ERROR (MainThread) [supervisor.backups.backup] Can't read backup tarfile /data/backup/ad0058c0.tar: unexpected end of data
22-10-21 14:54:41 ERROR (MainThread) [supervisor.utils.dbus] D-Bus method org.freedesktop.DBus.Properties.call_get_all not exists!
22-10-21 14:54:50 ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquitto
22-10-21 15:09:05 ERROR (MainThread) [supervisor.utils.dbus] D-Bus method org.freedesktop.DBus.Properties.call_get_all not exists!
