Sorry, I’m new to HA, just installed it 2 days ago. I’m following the guide for installing Blink cameras, and they show up within HA. However, when I follow the directions on this script (while adjusting it to my camera names), it does nothing…
When I run the script, I don’t get anything file output in the /tmp directory. I’ve been messing w/ this for a couple of hours now, and I can’t figure out what I’m doing wrong. I’ve not yet setup any scripts or automations, so I’m also learning as I go.
Verify folder permissions for /tmp/ are correct for your home-assistant user, also is that supposed to be tmp from / the root of the drive or inside your config folder.
So do you have a /tmp folder at the root of your drive? Because that’s where /tmp would be. If trying to do inside config folder you may want to try the full path /home/homeassistant/.homeassistant/tmp (if that’s how yours is)
As far as permissions, how did you install? If you have command line cd to the folder and “ls -al” will show you all files owners and permissions
I have updated to try and use /config/tmp. I installed a hassio on a VM. Assuming what you’re saying, I should point to - /home/homeassistant/.homeassistant/config/tmp?
If that’s your path to config… it should work with /tmp as well since you have it in the whitelist… was just making sure you had a folder at /tmp since that’s where it was pointing in your first example… did you get a chance to check the permissions?
