[HELP] can't install HACS using integration
Hi All,
I tried all the things you mentioned here but nothing helps. and whenever I try to add the HACS integration from configuration I always get this window, like something is not right, and once I put my git token it doesn’t add the HACS to the side panel.
any suggestions?
