just installed the HA on Virtualbox, i can see the installation done and see the following messages:
udevd[322] starting version 3.2.9
udevd[323] starting eudev- 3.2.9
udevd[181] starting version 3.2.9
udevd[182] starting eudev- 3.2.9
but i still cant reach the hassio UI:
i’ve tried hassio.local:8123 -> gets DNS_probe_finished_NXDOMAIN
i’ve tried [the laptop’s ip]:8123 ->gets connection refused
Could you explain a bit more on the situation?
where is your virutalbox running which device
from where are you trying to reach HA.
do you use pi-hole?
Hi. I notice your IPv4 adresses are on a different range.
I assume your current working IP range is 192.168.1.2 to 192.168.1.255.
You have 192.168.1.23 (laptop is correct)
you should not have 192.168.56.1 for VM.
It should be 192.168.1.xxx And ofcourse, this last digit cannot be .1
The above is correct if you have NOT put a forwarding rule in place on your router
i’ve changed the IP to one in the Subnet, but still cant reach it through web…
i’ve changed it to 192.168.56
when im searching for this device in my router, i cant see it, but in the laptop slot on the router it seems like it has static IP even though its DHCP and the VM is static.
im still a bit puzzled on what you are doing.
Do you have old laptop running windows? What OS?
And you have installed Virtualbox on this old laptop right?
And from that same laptop, are you trying to reach the virtual OS HA?
Or are you trying to reach it from another pc?
What are you typing to reach HA? port number etc… http or https?
Could you explain it a little bit more.
Dont forget HA needs time to do its first install. can take a while…
