Since 0.94.4, I’ve been unable to upgrade to the latest version of HomeAssistant. When I try to upgrade (through the hass.io menu or ssh), it looks like it’s updating and downloads the latest docker image. HomeAssistant then restarts but it just relaunches the 0.94.4 docker image.
I’ve tried to reinstall Hass.io a fresh and then restoring a snapshot. The initial reinstall brought me up to the latest update, however after restoring the snapshot, I end up back at 0.94.4. And then the same update issue comes back.
Here’s a log from HassOS. For the most part, though, there’s nothing that sticks out as a reason causing the failed update.
19-07-07 11:23:47 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:23:47 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:23:48 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:23:48 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:23:48 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:23:52 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:23:52 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:23:52 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:23:53 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:23:53 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:23:53 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:23:57 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:23:57 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:23:57 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:23:58 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:23:58 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:23:58 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:02 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:02 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:02 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:03 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:03 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:03 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:07 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:07 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:07 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:08 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:08 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:08 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:10 INFO (SyncWorker_1) [hassio.docker.interface] Tag image homeassistant/qemux86-64-homeassistant with version 0.94.4 as latest
19-07-07 11:24:10 INFO (SyncWorker_1) [hassio.docker.interface] Stop homeassistant application
19-07-07 11:24:12 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:12 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:12 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:13 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:13 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:13 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:17 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:17 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:17 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:18 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:18 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:18 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:19 INFO (SyncWorker_1) [hassio.docker.interface] Clean homeassistant application
19-07-07 11:24:19 INFO (SyncWorker_1) [hassio.docker.interface] Cleanup images: ['homeassistant/qemux86-64-homeassistant:0.95.4']
19-07-07 11:24:21 INFO (SyncWorker_0) [hassio.docker.homeassistant] Start homeassistant homeassistant/qemux86-64-homeassistant with version 0.94.4
19-07-07 11:24:22 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:22 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:22 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:23 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:23 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:23 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:26 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation in progress
19-07-07 11:24:27 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:27 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:27 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:28 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:28 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:28 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:32 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:32 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:32 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:33 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:33 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:33 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:37 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:37 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:37 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:38 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:38 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:41 INFO (MainThread) [hassio.homeassistant] Home Assistant pip installation done
19-07-07 11:24:42 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:42 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:42 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:43 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:43 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:43 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:47 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:47 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:47 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:48 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:48 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:48 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:52 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:52 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:52 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:53 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:53 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:53 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
19-07-07 11:24:56 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-07-07 11:24:56 INFO (MainThread) [hassio.homeassistant] Successful run Home Assistant 0.94.4
19-07-07 11:24:57 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:57 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_appdaemon3
19-07-07 11:24:57 INFO (MainThread) [hassio.homeassistant] Updated Home Assistant API token
19-07-07 11:24:57 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-07-07 11:24:58 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize
19-07-07 11:24:58 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered
19-07-07 11:24:58 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request running
19-07-07 11:25:18 INFO (MainThread) [hassio.api.security] /supervisor/logs access from core_ssh
