Hi All,
Wondering what is the best flow needed to set up the CCTV stream using frigate, go2rtc, rtsp2web, and HA.
I do have Frigate run (old version), rtsp2web, and HA. Currently, I believe each will connect directly to the camera. I did install go2rtc but at the time confused on how to set it up with a good flow.
At the moment my understanding is to connect all my cameras to Frigate → go2rtc → HA (without rtsp2web ← is this correct?) Maybe need more info. Furthermore, should I set up go2rtc from Frigate? or I should do config from go2rtc?
