Jokerigno
(Jokerigno)
August 1, 2020, 5:14pm
1
I’m using a script that calls xiaomi aqara and I want to switch to another media player.
this is the original one:
script:
alarm_script_play_soud_gateway:
sequence:
- service: xiaomi_aqara.play_ringtone
data_template:
gw_mac: !secret xiaomi_gateway1_mac
ringtone_id: "{{ ringtone_id }}"
ringtone_vol: "{{ ringtone_vol }}"
that is called in many other scripts like this one
alarm_gateway1_play_pending_sound_day:
sequence:
- condition: numeric_state
entity_id: input_number.gateway1_pending_volume_day
above: 0
- service: script.alarm_script_play_soud_gateway
data_template:
ringtone_id: "{{ states('input_select.gateway1_pending_sound_day').split('-')[0] | int }}"
ringtone_vol: "{{ states('input_number.gateway1_pending_volume_day') | int }}"
where those input_select are defined in an array:
sound_gateway1: [
"1 - Allarme Armato",
"2 - Allarme Disinserito",
"3 - Allarme in Attivazione",
"4 - Allarme Innescato",
"5 - Allarme Ritardato"
This is what I made so far but is full of error and obviously doesn’t work:
script:
sequence:
- service: media_player.play_media
entity_id: media_player.broadcast
data_template:
ringtone_id: >
{% if is_state("1 - Allarme Armato") %}
http://192.168.2.101:8123/local/allarmearmato.mp3”
{%-elif is_state("2 - Allarme Disinserito") %}
http://192.168.2.101:8123/local/allarmedisinserito.mp3”
{%-elif is_state("3 - Allarme in Attivazione") %}
http://192.168.2.101:8123/local/allarmeinattivazione.mp3”
{%-elif is_state("4 - Allarme Innescato") %}
http://192.168.2.101:8123/local/allarmeinnescato.mp3”
{%-elif is_state("5 - Allarme Ritardato") %}
http://192.168.2.101:8123/local/allarmeritardato.mp3”
{% else %}
none
{% endif %}
media_content_type: 'music'
Can someone please help me?
Thank you in advance!
KTibow
(Kendell R)
August 1, 2020, 5:50pm
2
You’re close. You need an entity_id
script:
sequence:
data_template:
ringtone_id: >
{% if is_state("input_select.change_this_id", "1 - Allarme Armato") %}
{%-elif is_state("input_select.change_this_id", "2 - Allarme Disinserito") %}
{%-elif is_state("input_select.change_this_id", "3 - Allarme in Attivazione") %}
{%-elif is_state("input_select.change_this_id", "4 - Allarme Innescato") %}
{%-elif is_state("input_select.change_this_id", "5 - Allarme Ritardato") %}
{% else %}
none
{% endif %}
Jokerigno
(Jokerigno)
August 2, 2020, 8:51am
3
OK but this config is quite complex and there are different input_select ( six).
How can I adapt the code?
with a sequence of others elif?
KTibow
(Kendell R)
August 2, 2020, 2:09pm
4
You only need one input select, with multiple choices. And there are only 5 options.
123
(Taras)
August 2, 2020, 2:10pm
5
If all you want is to reduce the template’s size, you can do it like this:
script:
sequence:
data_template:
ringtone_id: >
{% set d = {'1':'allarmearmato', '2':'allarmedisinserito', '3':'allarmeinattivazione', '4':'allarmeinnescato', '5':'allarmeritardato'} %}
{% set s = states('input_select.change_this_id')[:1] %}
{{ 'http://192.168.2.101:8123/local/' ~ d[s] ~ '.mp3' if s in d.keys() else 'none' }}
Jokerigno
(Jokerigno)
August 6, 2020, 9:42am
6
great. But I don’t need to use input select anymore.
I prefer to pass to this script a value in another script.
For example:
script:
play_trigger_sound:
sequence:
- service: script.alarm_script_play_sound_gateway
data_template:
ringtone_id: {{ "1" }}
and so on other scripts with different Ids based on different sounds.
How I have to change the script (my delayed response is because I tried to figure it out my self in these 4 days but I’m losing my mind)
Please support !
123
(Taras)
August 6, 2020, 1:05pm
7
You can use this script:
play_trigger_sound:
sequence:
ringtone_id: 1
to call this one:
alarm_script_play_sound_gateway:
sequence:
data_template:
ringtone_id: >
{% set d = {1:'allarmearmato', 2:'allarmedisinserito', 3:'allarmeinattivazione', 4:'allarmeinnescato', 5:'allarmeritardato'} %}
{{ 'http://192.168.2.101:8123/local/' ~ d[ringtone_id] ~ '.mp3' if ringtone_id in d.keys() else 'none' }}
Jokerigno
(Jokerigno)
August 6, 2020, 3:37pm
8
Using this:
play_trigger_sound:
sequence:
ringtone_id: 1
sequence:
data_template:
ringtone_id: >
I get some errors :
2020-08-06 17:40:24 ERROR (MainThread) [homeassistant.components.script.alarm_script_play_sound_gateway] alarm_script_play_sound_gateway: Error executing script. Invalid data for call_service at pos 1: extra keys not allowed @ data[‘ringtone_id’]
2020-08-06 17:40:24 ERROR (MainThread) [homeassistant.components.script.play_trigger_sound] play_trigger_sound: Error executing script. Invalid data for call_service at pos 1: extra keys not allowed @ data[‘ringtone_id’]
2020-08-06 17:40:24 WARNING (MainThread) [homeassistant.components.automation] Error Counting Automation: Already running
2020-08-06 17:40:24 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140654367622768] extra keys not allowed @ data[‘ringtone_id’]
123
(Taras)
August 6, 2020, 4:22pm
9
Sorry, I’m unfamiliar with the media_player’s services. According to the documentation for media_player.play_media , it indicates to use media_content_id
and its value depends on the capabilities of the device you are using for media_player.broadcast
Try this:
sequence:
data_template:
media_content_id: >
