Hello everyone. I need to write a research paper. I want to create a work that will be beneficial for me and the community. I have chosen an approximate topic related to matter, thread, home assistant, etc. Can you advise on what specifically I can research or test? Thankful for any help
Home automation: a wise balance between freeing a person from routine tasks & maintaining/monitoring/infinite improvement
ΠΠ²ΡΠΎΠΌΠ°ΡΠΈΠ·Π°ΡΠΈΡ ΡΠΌΠ½ΠΎΠ³ΠΎ Π΄ΠΎΠΌΠ°: Π²ΡΠ±ΠΎΡ Π±Π°Π»Π°Π½ΡΠ° ΠΌΠ΅ΠΆΠ΄Ρ ΠΈΠ·Π±Π°Π²Π»Π΅Π½ΠΈΠ΅ΠΌ ΡΠ΅Π»ΠΎΠ²Π΅ΠΊΠ° ΠΎΡ ΡΡΡΠΈΠ½Ρ ΠΈ ΡΡΠ°ΡΠΎΠΉ Π²ΡΠ΅ΠΌΠ΅Π½ΠΈ Π½Π° Π°Π΄ΠΌΠΈΠ½ΠΈΡΡΡΠΈΡΠΎΠ²Π°Π½ΠΈΠ΅/ΠΌΠΎΠ½ΠΈΡΠΎΡΠΈΠ½Π³/Π±Π΅ΡΠΊΠΎΠ½Π΅ΡΠ½ΠΎΠ΅ ΡΠ»ΡΡΡΠ΅Π½ΠΈΠ΅
Do you add βΡΡΠ°ΡΠΎΠΉ Π²ΡΠ΅ΠΌΠ΅Π½ΠΈβ in Russian because otherwise the phrase loses precision? I see this in other languages as well, when in comparison to English certain constructs require to be more explicit for proper style or to remove ambiguity.
This is a correct phrase.
But ofc I could say in English: β& spending precious time for maintaining/monitoring/infinite improvementβ )))
Yes, I know. My question was only based on linguistical curiosity.
Whatβs the scientific discipline in which you are working? It matters quite a bit whether you are in Sociology or Mechanical Engineering, while in either of these disciplines (and many others) HA could be an interesting topic.
My discipline is telecommunications and radio engineering
In that case, how about avoiding and mitigation of crowding in the 2.4 GHz band with the increasing adoption of smart home products and so many different protocols (Zibee, Wifi, Thread, Bluetooth) all using that part of the spectrum. Can the open home community contribute to that?
WOW! Thank you for your extensive response. This is a hot topic, especially in Ukraine, where I come from.
