I’m a bit overwhelmed by the information I can find online, and it’s a bit hard to choose.
I want to find a device that implements OpenTherm, will work either with Zigbee or zwave, and could be controlled by a temperature sensor through HA.
Can you please recommend devices that do not require a lot of tinkering/flashing/soldering?
Hardware that I have right now
- combi boiler with OpenTherm support
- home assistant on raspberry pi with Zigbee and zwave setup
- temperature sensor inside a room that is connected to HA
