Help! - Client exceeded max pending messages
I have started getting these messages
2017-11-11 16:35:59 ERROR (MainThread) [homeassistant.components.websocket_api] WS 140629041736392: Client exceeded max pending messages [2]: 512
Any ideas ?
Same here, started ~ 0.58
I’m getting it too but seemingly on when I use an automation to turn a few lights on based on motion being detected by a sensor…
Same here:
2017-11-30 17:19:06 ERROR (MainThread) [homeassistant.components.websocket_api] WS 1709437968: Client exceeded max pending messages [2]: 512
Started with 0.58.1 also. No other modifications made to automations or scripts, just the update. Strange.
I’m getting this too.
[homeassistant.components.websocket_api] WS 1844349200: Client exceeded max pending messages [2]: 512
Same here on version 0.63. First time I see it !
Having the same error. Opened up an issue on github. Please add your info: https://github.com/home-assistant/home-assistant/issues/12624
I get this when I reload automations from the ā€œconfig/coreā€ page.
Add me to the list.
This error:
ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.139906340336304] Client exceeded max pending messages [2]: 512
Is preventing me from reloading automations. However a config check passes and HA reloads without error.
I’ll join the party. Seeing this when nodered is loaded and I reload automations. If I turn NR off, no errors.
I removed all statistics sensors and replaced with filter sensors. This fixed this problem for me.
I had same error and I wonder if it had something to do with statistics sensors and (in my case) Appdaemon integration.
I’m seeing these errors as well. The latest is (and as usual non-descript):
2020-01-15 07:10:35 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2908314800] Client exceeded max pending messages [2]: 512
2020-01-15 07:10:35 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.2908314800] Connection closed by client
2020-01-15 07:26:52 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2887782256] Client exceeded max pending messages [2]: 512
2020-01-15 07:26:52 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.2887782256] Connection closed by client
2020-01-15 07:55:25 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.2885491728] Client exceeded max pending messages [2]: 512
Interestingly, right before this, I had a roku error:
2020-01-15 07:05:52 INFO (MainThread) [homeassistant.components.websocket_api.http.connection.2922440624] Connection closed by client
2020-01-15 07:09:51 ERROR (MainThread) [aiohttp.server] Error handling request
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_protocol.py", line 418, in start
    resp = await task
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_app.py", line 458, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.7/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/real_ip.py", line 40, in real_ip_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 73, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 136, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 123, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/api/__init__.py", line 355, in post
    domain, service, data, True, self.context(request)
  File "/usr/src/homeassistant/homeassistant/core.py", line 1235, in async_call
    await asyncio.shield(self._execute_service(handler, service_call))
  File "/usr/src/homeassistant/homeassistant/core.py", line 1260, in _execute_service
    await handler.func(service_call)
  File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 205, in handle_service
    self._platforms.values(), func, call, service_name, required_features
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 336, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 358, in _handle_service_platform_call
    await getattr(entity, func)(**data)
  File "/usr/src/homeassistant/homeassistant/components/roku/media_player.py", line 221, in select_source
    channel.launch()
  File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 95, in launch
    self.roku.launch(self)
  File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 304, in launch
    return self._post('/launch/%s' % app.id, params=params)
  File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 210, in _post
    return self._call('POST', path, *args, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/roku/core.py", line 227, in _call
    raise RokuException(resp.content)
roku.core.RokuException: b''
I included the log entry at the top because it might have something to do with the issue. But it happened a few minutes earlier, so probably not.
The Roku script is called from appdaemon and there is a corresponding error in the appdaemon error log:
2020-01-15 07:09:51.640246 WARNING AppDaemon: ------------------------------------------------------------
2020-01-15 07:09:51.640697 WARNING AppDaemon: Unexpected error in worker for App util_media:
2020-01-15 07:09:51.641134 WARNING AppDaemon: Worker Ags: {'name': 'util_media', 'id': UUID('fd3118e6-d9b3-4c7b-9ca8-cfdbf0c26aa6'), 'type': 'attr', 'function': <bound method util_media.cb_media_turn_on of <util_media.util_media object at 0xb49bb178>>, 'attribute': 'state', 'entity': 'media_player.bedroom', 'new_state': 'home', 'old_state': 'idle', 'kwargs': {'attribute': 'state', 'new': 'home', 'old': 'idle', 'attached_tv': 'switch.mbr_tv', 'channel_default': 'Tablo TV', 'remote_entity': 'remote.bedroom', 'remote_commands': ['right', 'down', 'down', 'down', 'down', 'down', 'down', 'select'], 'remote_delay': 6, 'override_channel': False, 'turn_on_entry': 'turn_on_2', 'handle': UUID('459ac398-a35c-4d75-8bb4-eeea2f7e0385')}}
2020-01-15 07:09:51.641415 WARNING AppDaemon: ------------------------------------------------------------
2020-01-15 07:09:51.643003 WARNING AppDaemon: Traceback (most recent call last):
  File "/usr/lib/python3.8/site-packages/appdaemon/appdaemon.py", line 594, in worker
    funcref(entity, attr, old_state, new_state,
  File "/config/appdaemon/apps/python files/util_media.py", line 197, in cb_media_turn_on
    self.worker_turn_on_media(roku_entity=entity,
  File "/config/appdaemon/apps/python files/util_media.py", line 347, in worker_turn_on_media
    self.call_service("media_player/select_source", entity_id=roku_entity, source=to_channel)
  File "/usr/lib/python3.8/site-packages/appdaemon/plugins/hass/hassapi.py", line 22, in func_wrapper
    return func(*args, **kwargs)
  File "/usr/lib/python3.8/site-packages/appdaemon/plugins/hass/hassapi.py", line 522, in call_service
    r.raise_for_status()
  File "/usr/lib/python3.8/site-packages/requests/models.py", line 940, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 500 Server Error: Internal Server Error for url: http://hassio/homeassistant/api/services/media_player/select_source
2020-01-15 07:09:51.643315 WARNING AppDaemon: ------------------------------------------------------------
I’m planning to rewrite this into a standard automation to see if that fixes anything.
Anyone see anything that can point to the issue? Is there any way to track down the exact http connection from the number at the end of error?
