I had the March Version of Home Assistant installed on my QNAP Container Station and tried to update to the latest version. I followed the steps here: Alternative - Home Assistant. However, I look to have completely messed it up. HA now loads, it recognises some of my devices, but I can’t use anything. for example when I click on Overview, there is no option to add to the dashboard (my old dashboard has disappeared), my HACS has disappeared and most of the configuration options are gone.
I think the best idea is to start afresh, but every time I delete the container and reload it, it still recognises a few of the old devices and leave me in a position where I can’t do anything. How do I delete everything and start again?
Also, if I do get going again, how do I update the container without all this hastle?
I just deleted the container within Container Station. I assumed that would remove the container and image. The folder with the conf.yaml and HACS were not deleted. (I should say I am fairly new to docker and HA).
Ok, I did get to this stage before, but I was unable to install HACS (I use Hubitat so need HACS to run this integration). I’ll give it another go and let you know how I get on. Thanks for now. BTW this version is 2021.5.4 (so I assume May), is there a later version for docker?
I’ll take a look at that in a moment. I am now trying to find the configuration.yaml file and the directory to point to in HACS, at the moment all I have is this:
Hello everyone… the same for me:
I have the Home Assistant 2021.7.0 installed and configured and I already did a lot of upgrades during the past two years.
Ha is showing me that there is a new version (2021.8.4)… but when I check for it in
Container Station → Docker Hub → homeassistant/home-assistant → select image version…
I can only view the oldest version (the latest version I can find in the Docker Hub menu is 0.119.0.dev20201216)
Last week I updated my Qnap to the current firmware version: 4.5.4.1741 and Container Station to 2.4.0.2316 version
Someone with this firmware/container station version could check the realease of homeassistant/home-assistant dockers, please?
Thanks a lot
