I’ve recently purchased a Sonoff POWR320D and flashed the esphome firmware with the template hosted on this site https://www.esphome-devices.com/devices/Sonoff-POW-Elite-20a
# Basic Config
substitutions:
friendly_name: POW Elite 20A
device_name: pow-elite-20a
esphome:
esp32:
board: nodemcu-32s
wifi:
ssid: !secret wifi_ssid
ap:
ssid: $device_name
password: !secret wifi_failover
captive_portal:
logger:
level: INFO
baud_rate: 0
api:
encryption:
key: !secret api_enc
ota:
password: !secret ota_pwd
esp32_ble_tracker:
scan_parameters:
interval: 1100ms
window: 1100ms
active: true
bluetooth_proxy:
active: true
uart:
rx_pin: GPIO16
baud_rate: 4800
time:
- platform: homeassistant
- platform: cse7766
update_interval: 2s
current:
voltage:
power:
on_value_range:
- above: 4.0
then:
- light.turn_on: switch_led
- below: 3.0
then:
- light.turn_off: switch_led
energy:
- platform: total_daily_energy
name: $friendly_name Total Daily Energy
power_id: w_sensor
- platform: wifi_signal
name: $friendly_name Wifi RSSI
update_interval: 60s
- platform: uptime
internal: True
on_raw_value:
then:
- text_sensor.template.publish:
state: !lambda |-
int seconds = round(id(uptime_sensor).raw_state);
int days = seconds / (24 * 3600);
seconds = seconds % (24 * 3600);
int hours = seconds / 3600;
seconds = seconds % 3600;
int minutes = seconds / 60;
seconds = seconds % 60;
return (
(days ? to_string(days) + "d " : "") +
(hours ? to_string(hours) + "h " : "") +
(minutes ? to_string(minutes) + "m " : "") +
(to_string(seconds) + "s")
).c_str();
name: $friendly_name ESP32 Internal Temp
device_class: temperature
unit_of_measurement: °C
lambda: return temperatureRead();
name: $friendly_name Power Factor
device_class: power_factor
lambda: return id(w_sensor).state / id(v_sensor).state / id(a_sensor).state;
- platform: esp32_hall
name: $friendly_name ESP32 Hall Sensor
binary_sensor:
- platform: gpio
pin: GPIO00
internal: true
filters:
- invert:
- delayed_off: 10ms
on_click:
- max_length: 350ms # short press to toggle the relay
then:
switch.toggle: relay_1
- min_length: 360ms # long press to cycle display info
max_length: 3s
then:
- if:
condition:
binary_sensor.is_on: page
then:
binary_sensor.template.publish:
state: OFF
else:
state: ON
- platform: template # this is a fake sensor to tell the screen which info to show on display
publish_initial_state: true
internal: true
display:
platform: tm1621
cs_pin: GPIO25
data_pin: GPIO14
read_pin: GPIO26
write_pin: GPIO27
lambda: |-
if (id(page).state) {
it.display_voltage(true);
it.display_kwh(false);
it.printf(0, "%.1f", id(v_sensor).state);
it.printf(1, "%.1f", id(a_sensor).state);
} else {
it.display_voltage(false);
it.display_kwh(true);
it.printf(0, "%.1f", id(wh_sensor).state);
it.printf(1, "%.1f", id(w_sensor).state);
output:
- platform: ledc
pin:
number: GPIO18
inverted: True
switch:
optimistic: true
lambda: |-
if (isnan(id(w_sensor).state)) {
return {};
} else if (id(w_sensor).state > 4) {
// Running
return true;
} else {
// Not running
return false;
turn_off_action:
- switch.turn_on: relay_off
turn_on_action:
- switch.turn_on: relay_on
- platform: gpio
restore_mode: ALWAYS_OFF
internal: true
pin: GPIO04
on_turn_on:
- delay: 500ms
- switch.turn_off: relay_off //bi-stable relay so no need to keep on.
interlock: [relay_on]
- platform: gpio
internal: true
pin: GPIO02
on_turn_on:
- delay: 500ms
- switch.turn_off: relay_on //bi-stable relay so no need to keep on.
interlock: [relay_off]
- platform: restart
text_sensor:
icon: mdi:clock-start
- platform: wifi_info
ip_address:
ssid:
bssid:
light:
- platform: monochromatic
output: led
internal: True
- platform: status_led
internal: True
pin:
number: GPIO05
inverted: True
interval:
- interval: 30s
then:
if:
condition:
wifi.connected:
then:
- light.turn_on: wifi_status_led
else:
- light.turn_off: wifi_status_led
All seems to work without problem but the relay doesn’t. POWR320D (POWR316D only have 1 pin relay) have the relay shared between GPIO02 On and GPIO04 Off as you can see on the pinout:
| Pin | Function |
| GPIO00 | Push Button (HIGH = off, LOW = on) |
| GPIO02 | Relay1 (320D - bi-stable - On) |
| GPIO04 | Relay1 (320D - bi-stable - Off) |
| GPIO05 | Wifi_LED |
| GPIO14 | TM1621 DA |
| GPIO16 | CSE7766 Rx |
| GPIO18 | Status LED (HIGH = off, LOW = on) |
| GPIO25 | TM1621 CS |
| GPIO26 | TM1621 RD |
| GPIO27 | TM1621 WR |
With tasmota I’ve no problem, but I prefer ESPhome because the integration with HA and versatibility
Can someone help with the config? I have very low knowledge on programing ESPhome
