Help! Configuring an HM-SEC-SC-2 for automation
Hello there,
i need to configure automation for my Homematic HM-SEC-SC-2. In the “states” section i found it as an binary sensor.
Entity                         state    Attributes
binary_sensor.state            off      battery: High
                                        sabotage: No
                                        rssi: 0
                                        interface: hmrf
                                        friendly_name: Fensterkontakt Esszimmer
                                        device_class: opening
i tried this in my automation.yaml:
- alias: Esszimmerfenster offen
    platform: state
    entity_id: binary_sensor.MEQ1597137
    to: "on"
    service: notify.pushover
      message: "Das Esszimmer Fenster wurde geöffnet!"
but it didn’t work :frowning:
how can i get the information from the device for an automation?
thanks in advance
Stephan
What is the name of the entity?
binary_sensor.state or
I think it is “binary_sensor.state” so you have to enter this name to the trigger. Or you shoult take a look at the name of your sensors. My homatic sensor was automagicaly named like this: binary_sensor.oeq3428197_state
But perhaps i am wrong.
By the way i have
resolvenames: json
in the ccu definition
That’s correct if names don’t get resolved. With resolving names it would be something like binary_sensor.resolvedname_state. Everything else would mean the entity ID has been modified (via entity registry).
Thanks, that’ correct. with “state” it works!
cheers
Stephan
