Hello
I have just switched from Smartthings to Home Assistant couple ago and so far I am really excited about the possibilities. I am currently trying to add my Schlage BE469 Deadbolt and I can’t get it to work.
I first added it as secure node but it wouldn’t open/close from HA. After doing some reading, it sounds like I needed to enable network key first. However I am super confused where exactly I do that.
What I did was add a line to configuration.yaml as follows:
I then added the deadbolt as secure node again, but I am still unable to open/close it.
When I try it the log shows this command:
ERROR: Dropping command, expected response not received after 1 attempt(s)
I feel like it’s still related to the network key but I am not sure where exactly am I supposed to configure it, or what other troubleshooting steps I should take. Any help would be greatly appreciated!
Thank you!
