Help Configuring the "Wait Until" Node - Node RED
Hi Guys,
Can anyone assist me with a problem im having, I am trying to configure the Home Assistant Node Red “Wait Until” Node but I can figure out what I am doing wrong.
Basically what I am looking to achieve here is I want the node to wait until the temperature in my rack has fallen back below the alerting threshold which I have specified using an input number.
sensor.server_rack_monitor_temperature
input_number.server_rack_temperature_alerting_threshold
This:
[{"id":"92d616b.35113e8","type":"inject","z":"6cd0b2f8.4bb6fc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":170,"y":640,"wires":[["4ab6f1e.c20381"]]},{"id":"4ab6f1e.c20381","type":"api-current-state","z":"6cd0b2f8.4bb6fc","name":"Get input number state","server":"9405c3fe.d0a6c","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":false,"entity_id":"input_number.server_rack_temperature_alerting_threshold","state_type":"num","state_location":"threshold","override_payload":"msg","entity_location":"","override_data":"none","blockInputOverrides":true,"x":350,"y":640,"wires":[["b8dd88bf.774788"]]},{"id":"b8dd88bf.774788","type":"ha-wait-until","z":"6cd0b2f8.4bb6fc","name":"","server":"9405c3fe.d0a6c","outputs":1,"entityId":"sensor.server_rack_monitor_temperature","entityIdFilterType":"exact","property":"state","comparator":"is","value":"threshold","valueType":"msg","timeout":0,"timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":540,"y":640,"wires":[[]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","addon":true}]
Alternatively you can do this:
[{"id":"92d616b.35113e8","type":"inject","z":"6cd0b2f8.4bb6fc","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":140,"y":840,"wires":[["5b103b50.e62db4"]]},{"id":"5b103b50.e62db4","type":"ha-wait-until","z":"6cd0b2f8.4bb6fc","name":"","server":"9405c3fe.d0a6c","outputs":1,"entityId":"sensor.server_rack_monitor_temperature","entityIdFilterType":"exact","property":"state","comparator":"lte","value":"$number($globalContext(\"homeassistant.homeAssistant.states['input_number.server_rack_temperature_alerting_threshold'].state\"))","valueType":"jsonata","timeout":0,"timeoutType":"num","timeoutUnits":"seconds","entityLocation":"","entityLocationType":"none","checkCurrentState":true,"blockInputOverrides":true,"x":300,"y":840,"wires":[[]]},{"id":"9405c3fe.d0a6c","type":"server","name":"Home Assistant","addon":true}]
