To get the code formatted correctly for the forum paste the code in
the edit box, leaving a blank line at the start and end, then select
the code and click the </> button in the small menu bar at the top of
the edit box.
Now to your question I could be wrong but I don’t think sequence: is valid outside of a script, so the action should be to call a script I would think.
I think the issue might be because I was using “sequence” to represent a variable to pass to my shell command in my older release and it sounds like that word is now reserved for scripts. I will try updating the variable name and see if that works.
