Help converting multiple elif's to something less ugly
I’ve created this sensor using 6 binary inputs to generate a single int output. I know there has to be a smarter way to go about this but my searching hasn’t helped me out. Could someone point me in the right direction?
template:
  - sensor:
      - name: Current Displayed Channel
        state: >
          {% if is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'off') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'off') and is_state('binary_sensor.digit2_g', 'off') %}
            1
          {% elif is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'on') and is_state('binary_sensor.digit2_f', 'off') and is_state('binary_sensor.digit2_g', 'on') %}
            2
          {% elif is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'off') and is_state('binary_sensor.digit2_g', 'on') %}
            3
          {% elif is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'off') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'off') and is_state('binary_sensor.digit2_g', 'on') %}
            4
          {% elif is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'off') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'on') and is_state('binary_sensor.digit2_g', 'on') %}
            5
          {% elif is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'off') and is_state('binary_sensor.digit2_e', 'on') and is_state('binary_sensor.digit2_f', 'on') and is_state('binary_sensor.digit2_g', 'on') %}
            6
          {% elif is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'off') and is_state('binary_sensor.digit2_g', 'off') %}
            7
          {% elif is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'on') and is_state('binary_sensor.digit2_f', 'on') and is_state('binary_sensor.digit2_g', 'on') %}
            8
          {% elif is_state('binary_sensor.digit1', 'off') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'on') and is_state('binary_sensor.digit2_g', 'on') %}
            9
          {% elif is_state('binary_sensor.digit1', 'on') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'on') and is_state('binary_sensor.digit2_f', 'on') and is_state('binary_sensor.digit2_g', 'off') %}
            10
          {% elif is_state('binary_sensor.digit1', 'on') and is_state('binary_sensor.digit2_a', 'off') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'off') and is_state('binary_sensor.digit2_g', 'off') %}
            11
          {% elif is_state('binary_sensor.digit1', 'on') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'on') and is_state('binary_sensor.digit2_f', 'off') and is_state('binary_sensor.digit2_g', 'on') %}
            12
          {% elif is_state('binary_sensor.digit1', 'on') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'off') and is_state('binary_sensor.digit2_g', 'on') %}
            13
          {% elif is_state('binary_sensor.digit1', 'on') and is_state('binary_sensor.digit2_a', 'off') and is_state('binary_sensor.digit2_b', 'on') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'on') and is_state('binary_sensor.digit2_g', 'on') %}
            14
          {% elif is_state('binary_sensor.digit1', 'on') and is_state('binary_sensor.digit2_a', 'on') and is_state('binary_sensor.digit2_b', 'off') and is_state('binary_sensor.digit2_e', 'off') and is_state('binary_sensor.digit2_f', 'on') and is_state('binary_sensor.digit2_g', 'on') %}
            15
          {% else %}
            0
          {% endif %}
You are converting an arbitrary display (7 segment) into a number. There isn’t really an easier way. This is more compact but less readable:
        state: >
          {% set d1 = states('binary_sensor.digit1')|bool(0)|int %}
          {% set a = states('binary_sensor.digit2_a')|bool(0)|int %}
          {% set b = states('binary_sensor.digit2_b')|bool(0)|int %}
          {% set e = states('binary_sensor.digit2_e')|bool(0)|int %}
          {% set f = states('binary_sensor.digit2_f')|bool(0)|int %}
          {% set g = states('binary_sensor.digit2_g')|bool(0)|int %}
          {% set bin = (a ~ b ~ e ~ f ~ g)|string %}
          {% if bin == '01000' %}
            {{ (d1 ~ 1)|int }}
          {% elif bin == '11101' %}
            {{ (d1 ~ 2)|int }}
          {% elif bin == '11001' %}
            {{ (d1 ~ 3)|int }}
          {% elif bin == '01001' %}
            {{ (d1 ~ 4)|int }}
          {% elif bin == '10011' %}
            {{ (d1 ~ 5)|int }}
          {% elif bin == '10111' %}
            {{ (d1 ~ 6)|int }}
          {% elif bin == '11000' %}
            {{ (d1 ~ 7)|int }}
          {% elif bin == '11111' %}
            {{ (d1 ~ 8)|int }}
          {% elif bin == '11011' %}
            {{ (d1 ~ 9)|int }}
          {% else %}
            0
          {% endif %}
Or if your numbers displayed don’t go above 15:
        state: >
            {{ (d1 ~ 1)|int }}
            {{ (d1 ~ 2)|int }}
            {{ (d1 ~ 3)|int }}
            {{ (d1 ~ 4)|int }}
            {{ (d1 ~ 5)|int }}
            6
            7
            8
            9
          {% else %}
            0
          {% endif %}
Not even knowing what you want with this but in reality you have 64 combinations, as Tom said your first one is more readable but a possible (?) alternative is that you combine certain settings
There are actually less than that if they only expect the digits 0 to 15 to be displayed on the 7 segment displays, which is what it looks like from the original template.
Even if they wanted 0 to 99 there are only 10 combinations to decode (twice) if you decode it digit by digit then concatenate them into decimal.
If your goal is to get rid of the elif’s, you could take the first half of Tom’s template then use a map…
state: >
  {% set mapper = {
    '01000': '1', '11101': '2', '11001': '3',
    '01001': '4', '10011': '5', '10111': '6',
    '11000': '7', '11111': '8', '11011': '9' } %}
  {% if bin in mapper.keys() %}
    {{ (d1 ~ mapper.get(bin)) | int }}
  {% else %} 0 {% endif %}
template:
  - sensor:
        state: >
          {% set i = expand('binary_sensor.digit2_a', 'binary_sensor.digit2_b', 'binary_sensor.digit2_e',
            'binary_sensor.digit2_f', 'binary_sensor.digit2_g') | map(attribute='state')
            | map('bool', false) | map('int', 0) | join | int(0, 2) %}
          {% set d = {8: 1, 29: 2, 25: 3, 9: 4, 19: 5, 23: 6, 24: 7, 31: 8, 27: 9} %}
          {{ (states('binary_sensor.digit1') | bool(false) | int(0) ~ d.get(i)) | int(0) if i in d.keys() else 0 }}
Thanks for all the great suggestions. As some background, I’m interfacing with a 15 channel 433 RF remote that uses rolling codes. Using the RasbPi GPIO I’m going to read in the two 7 seg displays to determine which channel it is currently set to then output back to the remote buttons to change channels and perform other functions (it’s a remote for numerous roller shutters).
Using the original posted code with all the elsif’s works but I thought there must be a better way and it’s a good opportunity to improve my skills by working on a real world example.
It’s going to take me a bit to digest the solutions you have all so kindly contributed but from the outset they look interesting and I’m curious to work through each one.
