I have a well pump with an energy sensor telling HA when is it on or off. The pump fills up a water tank every night. I know how many liters per hour the pump provides. Can anybody help me with a template to convert that info into a sensor that I can use in the Energy Dashboard as water usage? Thank you.
I understand that you need the time that the pump is on and multiply that with a figure to get to the volume of water … You could try to use history stats for that
below is for current day, i.e. fro start… it uses ‘now’ and trips off the time making it start of day
- platform: history_stats
entity_id: MYPUMPSENSOR
state: "on"
type: time
start: "{{ now().replace(hour=0, minute=0, second=0) }}"
end: "{{ now() }}"
Thanks for the suggestion. The result of that sensor comes in X.X format (i.e. 2.5). Is that hours + minutes in decimal? (2.6 = 2 hours and 30 minutes). As far as I understand, I’ll have to create another sensor based on the result of sensor.pumpon…
Thanks again.
I guess so, you would have to verify the correctness of the response of course
And then yes, for as far as I can see you cannot use templating in the state of this history_stats (but I may very well be wrong too), else you could combine this …worth further investigating ?
Else you would need a second sensor for the multiplying, but you could possibly (??) do that directly in the utility meter setup.
Just bringing views/ideas as I donot have this setup…else I would have given the full solution
Did you end up solving for this?
Thanks I’ll take a look at that. Wondering if the pressure variation impacts the calculation. I may add a pressure sensor.
Probably it does but first goal is to add it to ha and make calculation aqurate as possible. Fine tuning comes later.
