Hi guys,
I’ve tried creating sensor template to ignore certain value (1000 in this case) but failed.
Could you please help?
Sensor output is taken from modbus device.
Here’s my current config:
Thank you kindly!
Hi guys,
Thank you kindly!
Please dont post pictures of text. Post the correctly formatted text. That way we can use copy/paste/edit to help you.
Sure, sorry, this was only thing I had on hand until now.
sensors:
filtered_pm25cleanr:
unit_of_measurement: μg/m3
value_template: "{% if states('sensor.pm25cleanr') == 1000 %} {% else %} {{ states('sensor.pm25cleanr') }} {% endif %}"
This should do it.
sensors:
value_template: >
{{ states('sensor.filtered_pm25cleanr') }}
{% else %}
{% endif %}
If the new value = 1000, keep that last value.
Thanks Tom, unfortunately this doesn’t do the job
When 1000 appears, it does use this value.
Try:
{% if states('sensor.pm25cleanr')|int == 1000 %}
or:
{% if states('sensor.pm25cleanr') == '1000' %}
States are always strings, so you can either convert and compare to a number, or compare to a string that looks like the number.
The |int did the job.
Thank you both!
