Hello guys,
I wonder if you could help me, ive been searching around but can’t find anything to even begin to work out how to achieve this.
Im looking to set up a template sensor for a local calendar I have created called “Social” I would like the sensor to pull the name of the next event in the calendar and store it as the state, and I would like the date of the event stored as an attribute called “Event Date”
I would be most grateful for any help you could offer.
thanks
Have you looked at the home feed card from HACS?
Thanks for the reply, im not looking for a card. I need the information in a template as I want to use it in a button and markdown card, thanks anyway
You will need to use a trigger-based template sensor that includes the calendar.get_events
service.
At a minimum, you will want to use a Calendar trigger, but you may want to include additional triggers to cover cases like when events are added to the calendar or HA restarts.
I believe what you want is what I have here:
trigger off the calendar event (albeit in an automation, but you could also do that in a trigger based template like Didgeridrew suggests), and then store that value in an input_text
do some more stuff, even create a todo item and notification
- id: create_todo_from_afvalwijzer_calendar
- platform: calendar
entity_id: calendar.afvalwijzer
event: start
offset: -06:00:00
event: start
offset: 07:00:00
condition: []
- service: input_text.set_value
entity_id: input_text.todo_afvalwijzer
value: >
{{trigger.calendar_event.description}}
- service: todo.add_item
entity_id: todo.huishouden
item: &item
Saver: {{trigger.calendar_event.description}}
description: &description
Opgelet: {{trigger.calendar_event.description}} aan de straat zetten.
due_date: &moment
{{trigger.calendar_event.start}}
- service: notify.mobile_app_marijn
title: *item
message: *description
your template could be done based on the newly set input_text, or use that directly even in a markdown card, without even having to create the template sensor at all
