I have a sensor for solar energy produced " sensor.solax_pv_power_total ".
I would like to use that but if it is a value higher than 3700W to track (as in a meter) how much is produced.
Use case, I have an oversized solar array of around 5500W. If I avoid the storage battery being full, at certain sweet spots in the day I can generate up to that 5500W from my panels. BUT if the battery is full then the inverter maxes out at 3700W. Wasting potentially 1800W of energy.
I am interested to see how much that is over some periods of time. I can then figure out if it is such a small amount that I am not getting the benefit from.
If for example (not often or likely) I could in theory generate 5500W for an hour continuously, but only generate 3700W, I know there was opportunity for 1800W more, or 1,8 kWh. It may be worth spending some time trying to take advantage of this by changing how I charge the storage battery dependant on forecast etc.
It might end up being so small that I just CBA!
Can I get any pointers? If I get a reading then I can add a utility meter helper to it.
Going to be something like If its over 3700 then record the value -3700. If it is under 3700 then record 0.
Think I have cracked it. I have set using 3760 which is my inverter specs.
I have made a package file as have some others. THis once is called oversized_pv_array.yaml.
Includes the sensor, the integration (riemann sum integral) and the utility meter all in one file.
- sensors:
pv_power_oversized_array:
friendly_name: "Power from oversized array"
value_template: >-
{% set actual_power = states('sensor.solax_pv_power_total') | float %}
{% if actual_power < 3760 %}
0
{% else %}
{{ actual_power - 3760 }}
{% endif %}
unit_of_measurement: "W"
# All set up 25th April 2024 so readings not recognised before this
- platform: integration
source: sensor.pv_power_oversized_array
unit_prefix: k
round: 2
method: left
utility_meter:
pv_oversized_hourly:
source: sensor.pv_oversized_total
name: PV Oversized - This Hour
cycle: hourly
pv_oversized_daily:
name: PV Oversized - Day
cycle: daily
pv_oversized_week:
name: PV Oversized - Week
cycle: weekly
pv_oversized_month:
name: PV Oversized - Month
cycle: monthly
pv_oversized_year:
name: PV Oversized - Year
cycle: yearly
type or paste code here
