I came across this but I do not have a sonoff.
Do I have to remove the comments in my yaml?
Is there anything I would have to modify or delete since I’m not using a Sonoff ESPHome device?
I’m using another ESPHome smart plug.
# Basic Config
esphome:
platform: ESP8266
board: esp01_1m
libraries:
- ESP8266WiFi
- https://github.com/akaJes/AsyncPing#95ac7e4
external_components:
- source:
type: git
url: https://github.com/trombik/esphome-component-ping
ref: main
wifi:
ssid: xxxxxxxxxxxxxxxxxxx
password: xxxxxxxxxxxxxxxxxxx
ap:
ssid: "Sonoff5" # in case it can't connect and you need to reprogram it
password: "xxxxxxxxxxxxxxxxxxx"
logger:
baud_rate: 0 # (UART logging interferes with cse7766)
# Enable Home Assistant API
api:
encryption:
key: "xxxxxxxxxxxxxxxxxxx"
ota:
# Device Specific Config
uart:
rx_pin: RX
baud_rate: 4800
binary_sensor:
- platform: gpio
pin:
number: GPIO0
mode: INPUT_PULLUP
inverted: True
name: "Sonoff Cable Modem Button"
on_press:
- script.execute: power_cycle_relay
- platform: status
name: "Sonoff Cable Modem Status"
- platform: wifi_signal
name: "Sonoff Cable Modem WiFi Signal"
update_interval: 60s
- platform: cse7766
current:
name: "Sonoff Cable Modem Current"
accuracy_decimals: 1
voltage:
name: "Sonoff Cable Modem Voltage"
power:
name: "Sonoff Cable Modem Power"
- platform: ping
ip_address: 8.8.8.8
num_attempts: 1
timeout: 1sec
loss:
name: "Packet Loss to Internet"
latency:
name: "Latency to Internet"
accuracy_decimals: 3
update_interval: 30s
switch:
- platform: gpio
name: "Sonoff Cable Modem Relay"
pin: GPIO12
restore_mode: ALWAYS_ON
status_led:
pin: GPIO13
globals:
- id: last_power_cycle
type: time_t
restore_value: no
initial_value: '0'
- id: packet_loss_count
type: int
restore_value: no
initial_value: '0'
# Ping time (in seconds)
interval:
- interval: 60s
then:
- script.execute: ping_check
# Script for checking packet loss
script:
- id: ping_check
then:
- if:
condition:
# Condition checks if packet loss has occurred
lambda: 'return id(loss).state > 0;'
then:
# If packet loss has occurred, increment packet_loss_count
- lambda: |-
id(packet_loss_count) += 1;
// If there are 3 consecutive packet losses, reset the count and execute power_cycle_relay script
if (id(packet_loss_count) >= 3) {
id(packet_loss_count) = 0;
id(power_cycle_relay).execute();
else:
# If there's no packet loss, reset the packet_loss_count
- lambda: |-
# Script for power cycling the relay
- id: power_cycle_relay
then:
- lambda: |-
time_t now = id(esphome_time).now().timestamp;
// Do not power cycle during the first 15 minutes after boot
if (now < 900) {
ESP_LOGD("power_cycle_relay", "Skipping power cycle during the first 15 minutes after boot");
return;
// Do not power cycle if the last power cycle was less than 15 minutes ago
if ((now - id(last_power_cycle)) < 900) {
ESP_LOGD("power_cycle_relay", "Skipping power cycle since it's been less than 15 minutes since the last one");
return;
// Update the last power cycle timestamp and execute the power cycle
id(last_power_cycle) = now;
ESP_LOGD("power_cycle_relay", "Power cycling the relay due to button press or packet loss.");
id(relay).turn_off();
- delay: 5s
- lambda: |-
id(relay).turn_on();
time:
- platform: sntp
servers:
- 0.pool.ntp.org
